CD Changer problem
Old Jan 3, 2006 | 09:41 AM
Garff's Avatar
Garff
CD Changer problem
I have a ’00 with a 6 disk changer in the center console and I am getting an error msg on the radio stating the magazine is empty. Obviously I have CD’s in the magazine, any ideas on what could be wrong? I could pull the changer out, but who would work on it and any ideas on what kind of labor I would be looking at? If the labor to fix it is way out of line is there another option? Like an in dash changer from a newer model? I would like to keep the look stock, thus no aftermarket if possible. Thanks for any help.
Old Jan 3, 2006 | 09:46 AM
Grant12's Avatar
Grant12
Try running a cleaner disc or unplug the unit sometimes a reset helps but be sure you dont have security coded radio not sure if ford has that but I have dealt these issues in the past on toyotas.What is the product #?post it if you can find it!appreciate ya!
Old Jan 6, 2006 | 12:03 PM
lostaprop's Avatar
lostaprop
I am having the same problem with a 98. A cd clearner does not help out. I will try unplugging it next to reset it then cleaning it, but it does not recognize any discs, even the cleaner...
Old Jan 6, 2006 | 03:58 PM
Grant12's Avatar
Grant12
Lostaprop I love that avatar you either are good with pics or a google digging son of a gun.I hate to say but if none of these little tricks work and it will not read disc its probably junk,the laser eye is usually bad.appreciate ya!
Old Jan 6, 2006 | 06:55 PM
bcause's Avatar
bcause
I have the factory cassette deck and changer that I just took out of my '99 Expy if anyone is interested.
Old Jan 11, 2006 | 09:36 PM
natsoundup's Avatar
natsoundup
we just had this problem and I was about to order a new cd player.
My son took the whole unit out and disassembled it. I think two cd's were jambed or got jambed into one slot.
all seems to be fine now.
Old Jan 12, 2006 | 06:54 AM
Grant12's Avatar
Grant12
That can happen he sounds pretty sharp.Those things when disassembled can get confusing.I had to fix my home unit like that same problem.Natsoundup has got a good point remove the unit try to look for jams.appreciate ya!
