rear end ratio
Old Jan 3, 2006 | 08:54 AM
brownstraightsix's Avatar
brownstraightsix
rear end ratio
I have a 1984 f150 2x4 w/300 l6 with a c6 tranni and a completely stock drivetrain.
Does anyone know what the stock rear end ratio is??
Thanks
Old Jan 3, 2006 | 09:29 AM
oldhalftons's Avatar
oldhalftons
could be 2.75-4.10's. the door plate will have a axle code. that is what we need to tell for sure
Old Jan 3, 2006 | 10:15 AM
Silver Streak's Avatar
Silver Streak
Or look for a small stamped steel tag on one of the studs that holds the pumpkin in the housing (or the cover on the back if it's not a 9"). The ratio will be stamped in one of the corners of the tag. Mine is a 3.08, so it is stamped 3 08. If it was a factory limited slip is would be 3L08.
Old Jan 3, 2006 | 10:20 AM
fordborn's Avatar
fordborn
Thread moved to "1980 - 1986 F-Series Trucks" truck forum. Should fine more information on this year of truck here.
