power curves
Old Jan 3, 2006 | 02:18 AM
FFemt5287's Avatar
FFemt5287
power curves
97 psd with a zf5. anyone have power curve charts? trying to find a good shift point for max power/economy
Old Jan 3, 2006 | 08:20 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Which is it? For best economy keep the shift points below 2000 rpm and feather the throttle to get there. Max power shifts should be just before the rev limiter noses you over.
Old Jan 4, 2006 | 08:31 PM
444dieselrod's Avatar
444dieselrod
Peak torque is 1800rpm stock, mine was closer to 2000rpm, last time it was dynoed.
If ya got a pyro, I have discovered that if I try to maintaince a 10:1 ratio between EGT:speed. plus 100º I get the best economy.
example. 65 MPH, would be 750º
45 would be 550º
make sense??? call me ****, but I get bored when I drive, and I figure I got all these gauges, lets look at em.
Diesel Rod
Old Jan 4, 2006 | 09:59 PM
FFemt5287's Avatar
FFemt5287
i totally agree. someone told me that if i run up the boost before i shift, it'll turn out to be more efficient. any thoughts on this?
Old Jan 5, 2006 | 06:30 PM
cookie88's Avatar
cookie88
FTE Emeritus
Takes fuel to make boost, the more boost you run up, the more fuel you're using.
Old Jan 7, 2006 | 04:40 PM
444dieselrod
I normaly hold 3 psi boost when cruising, maybe hit 7 between gears unless I am on it hard, then into the 20's. and that gets me 18's with 4:10's and an auto.
Diesel Rod
