well guy's here it goes,89 E250 4.9L I did a full tune up with plugs/wires/cap/rotor then did the walker down pipe to 3" pipe aftermarket cat into a flowmaster turned out infront of the rear tire.sounds great but I seen to have lost most of my power and I'm down to 9mpg from 18mpg.nothing seems to be draging tires are full and I just put in a new air filter.I want my van back as I drive all over for my job and 9mpg is killing me.
thanks for the replys guy's,the timming is dead on 10* and the spout is in.I was thinking it was the pipe size to but there are alot of guy's running 3" pipe without problems but as usual I will be that one that can't run it.
I have some 21/2" pipe also that I could switch to or is that still to big as I think the walker down pipe is 21/2".
Going to 3" may hurt your power a bit, but it won't kill it. If it really is a noticable decrease in power i would look for PROBLEMS and not exhaust diameter.
