Auto Climate Problem
Old Jan 2, 2006 | 08:12 PM
ExpyBoy's Avatar
ExpyBoy
Front area not working.... No Blend Door Movement Noise... OH Yeah no Blower up front either ....Fuses and Relays all check out... any Ideas???
Old Aug 11, 2006 | 07:49 AM
Spgiles's Avatar
Spgiles
Front Ac blower on again off again
I have a similar problem - 2003 expedition - the front ac blower works sometimes and sometimes not.
Have you located your problem yet?
I took it to the dealer - after two hours he wanted to change the blower motor!
even though it was blowing at the time
A local mechanic talked about the brushes getting stuck then freeing up??
I think they are just guessing - hoping to find the problem as they dig into change the motor.
Old Aug 11, 2006 | 12:36 PM
Mr.Novice's Avatar
Mr.Novice
I'm thinking the front blower motor if all the other electronics check out...
Old Aug 11, 2006 | 08:04 PM
BowTieHatr's Avatar
BowTieHatr
do you have manual or atc? how do you know the blend door is not moving?
Old Aug 12, 2006 | 04:38 PM
Revrend's Avatar
Revrend
Same problem just hit me. I was driving along, and when I hit the gas, my air cut out. When I let off, it came right back. I figured I just never noticed the air giong down to allow the engine to push itself. Then I noticed it was doing it when I was barely on the gas. After we went to a store, we were welcomed to the air not working, at all. I turned off the Auto feature, then turned it back on, and it came blowing ice cold-okay, we know the compressor works. I too checked the fuses, they look fine. I don't know how to check the relay, though.
The rear AC is working perfectly, nice and cold, and very powerful.
Suggestions? I'd hate to take it to the dealer, because I'm really not a big fan of lying thieves.
Old Aug 12, 2006 | 09:02 PM
BowTieHatr's Avatar
BowTieHatr
not all of us are bad!!
Old Aug 12, 2006 | 09:46 PM
Revrend's Avatar
Revrend
While I believe you, it's really hard to find the 3 honest ones, when you travel for a living.
Also, to add to my problem...we noticed today that if we CRANK the AC and put it on the front vents, it only comes out the DEFROST vents, but it comes out of there hard. So...that leads me to think it's a switching problem somewhere, and not a blower one (but hey, what do I know about car AC systems?)
Old Aug 14, 2006 | 12:11 AM
Revrend's Avatar
Revrend
Nevermind, moot point. It was totaled today.
Old Aug 14, 2006 | 08:36 AM
projectSHO89's Avatar
projectSHO89
You have a vacuum leak. Most common location is the small black hose located between the battery and the firewall under the hood.
Stev
