i have a 1994 4.0 4x4with auto . tranny has stopped shifting forward and reverse . trans fluid is full and not burnt . any thoughts as to why its stopped shifting.
Mine was in a 89 BII. I found a 91 ranger with a FM146 (which is the same length as the A4LD) You have to add the clutch pedal and all the stuff with it Fly wheel will also be needed. If you look in the tech post in this fourm you will find a link to my swap it is titled A4LD to FM146.
Biggest pain was the cultch padel thats a tight place for a big guy like me to get into. Also if you dont get a tranny the same lenght then you have to move your cross member and change driveshafts.
