302/AOD Too Tight?
Old Jan 2, 2006 | 11:04 AM
CLWunschel's Avatar
CLWunschel
302/AOD Too Tight?
I dropped my 302/AOD setup into my 55 F-100 then tried to bolt the converter to the flex plate. Seems that the coupled engine and trans don't want to rotate after being bolted togther. Took the engine back out this a.m. and it spins fine. Turning the converter by hand works fine too, but the converter seems to move front to back as it spins instead of rotating in place. Bolt the 2 together and they won't spin. What may be going on? Trans is a fresh rebuild (by a trans shop). Engine and trans have spent many years together in a Lincoln Continental before being freshened up for their duty in the old pickup.
Old Jan 2, 2006 | 12:59 PM
stuart1's Avatar
stuart1
The convertor is not engaged into the pump properly.
