fuel pressure regulator mod
Old Jan 2, 2006 | 04:46 PM
PSNut's Avatar
PSNut
Originally Posted by jtharvey
Would an HPX line help with that too? How does increasing the fuel pressure with shims work in conjunction with a tuner or chip?
I didn't know that the number 8 injector was starved for fuel. I'm always learning something new here.
The HPX is for the injector oil system. The #8 injector is at the dead end so it doesn't get the same fuel volume.Stupid design.
Old Jan 2, 2006 | 04:51 PM
PSNut's Avatar
PSNut
Talking
Hey Pop,
looks like we're both hot on this thread at the same time...
Old Jan 2, 2006 | 08:11 PM
jtharvey's Avatar
jtharvey
So what about shimming the FPR in conjunction with a tuner or chip? Does the chip or tuner increase the fuel pressure? Or can the fuel pressure only be increased by mechanical means?
Old Jan 2, 2006 | 08:17 PM
Kwikkordead's Avatar
Kwikkordead
The fuel pressure can only be changed mechanically. It's a simple spring and valve.
Old Jan 2, 2006 | 08:21 PM
CAT_man_963's Avatar
CAT_man_963
With a chip or tuner - you are calling for MORE fuel - but it can't change the pressure - so if you've already got a low pressure problem - you might notice the FIX more, than with a stock setup.
Edit - ahh Kwik beat me anyhow - stupid hunt and peck
Old Jan 2, 2006 | 08:27 PM
Kwikkordead
Old Jan 2, 2006 | 09:10 PM
jtharvey's Avatar
jtharvey
So on my 6-Gun tuner (one of the first mods I bought-wouldn't do it again), there is a plug that goes into the ICP. Is this just telling the ICP to give it more fuel?
Old Jan 2, 2006 | 09:18 PM
PSNut's Avatar
PSNut
Change pulse width=more fuel.
Old Jan 2, 2006 | 10:20 PM
jtharvey's Avatar
jtharvey
Gotcha. Now I get it. I'll be shimming the FPR soon!
Thanks for the help!!
Old Jan 3, 2006 | 12:49 AM
jberylecrider's Avatar
jberylecrider
Originally Posted by SpringerPop
HPX= High Pressure Crossover. The HPOP's output, high-ressure oil, is regulated. The sensor is connected to only one head's "rail". Installing the HPX provides a connection for both high-pressure oil rails to work together. The end result is better high-pressure oil regulation, allowing the optimum for both rails to be equal pressure no matter individual demands. Typically, you'll notice a smoother idle.
Pop
So is this the fix for this or not?? Was this ever fixed by Ford? Is there a certain year this was not an issue any longer?? and lastly, how big of an issue is this really?? Does it cause damage, or just a little less power created in the one cylinder?
On another note, if you were to shim and get higher fuel pressure, it would be smart to use a tuner to shorten the pulse width so you get the same amount of fuel as before you raised the pressure, correct??
Old Jan 3, 2006 | 07:12 AM
Kwikkordead
You'll easily shorten the pulse width by giving it less throttle.
I am of the opinion that you don't want to shim beyond 70 psi. Push a design too far out of it's perameters and you'll start creating side issues that are unknown until they pop up. I mostly want to prevent unnecessary leaks.
JRogersOU
Aug 16, 2014 11:00 PM
jsavin
Feb 26, 2013 08:26 PM
slbuckl
Escape & Escape Hybrid
Jul 16, 2011 07:49 AM
robinsonpowerstroke
21
Jul 5, 2011 09:32 PM
bcaughhorn
Feb 7, 2011 12:48 PM
