Transmissions
Old Nov 7, 2001 | 07:21 AM
jowilker's Avatar
jowilker
Transmissions
Old Nov 7, 2001 | 06:19 PM
GreenHornet79's Avatar
GreenHornet79
Transmissions
Hi! I was wondering if anybody had any 4-speed tranny recommendations. I am planning on hooking it up to a 351W. I know it might depend on the year of the engine. I plan on using the original drive shaft if it will bolt up properly. Thanks
Old Nov 7, 2001 | 07:50 PM
Like M. Fords's Avatar
Like M. Fords
Transmissions
Besides 4 forward gears, what are you looking for? Overdrive, granny 1st, close ratio, strength, quick shifting? There are a variety of trannys that bolt up to the small-block. Some work better for an intended purpose than others.
Old Nov 8, 2001 | 03:33 PM
unreng's Avatar
unreng
Transmissions
GreenHornet79,
Is your truck 2wd or 4wd? What year truck? Heavy duty or light duty? The NP435 or T18/19 are two abundant 4-spd trannies in ford trucks (although they have granny gears). I'd have to check my shop manuals for any other trannies. I hope this helps.
Chris
