return fuel check valve ?
Old Jan 1, 2006 | 09:11 PM
jeffdoerr's Avatar
jeffdoerr
where can I get a good check valve. I pulled my old one out a few months ago and plugged the hole in the filter hsg. I would like to hook my return line back up, but I noticed the check valve is no longer a 1 way valve. The center is gone in it. Its a little brass thing, but no ball or spring is or was with it. I have heard that this style is no longer available for sale.
Old Jan 2, 2006 | 04:59 AM
tjc transport's Avatar
tjc transport
i ain't rite
if you are talking about the line that goes from the injector return rail to the top of the filter housing, leave it disconnected. this was a ford recommended tsb back in the early 90's. if you hook it back up, it will only give you a hard start problem again. there is more than sufficient return line in the rail.
Old Jan 2, 2006 | 08:14 AM
jeffdoerr's Avatar
jeffdoerr
the line I am refering to conects to the side of the filter hsg, next to the schraeder valve. I thought this line went back to the tank. It was recommended by the diesel shop to hook it back up. I will double check as to where the line goes today.
Old Jan 2, 2006 | 12:06 PM
PLC7.3's Avatar
PLC7.3
Go to http://www.intellidog.com/dieselmann/idi2.htm he has good info and the part # just get the right size on the part area ........ http://www.intellidog.com/dieselmann/idiparts.htm
JRogersOU
Aug 16, 2014 11:00 PM
23larry24
Jul 18, 2011 06:09 PM
SilverSport
Jan 16, 2007 06:34 PM
roakey
Jul 12, 2001 06:37 PM
