Sponsored by: Real Truck
starter relay?
Old Jan 3, 2006 | 07:15 PM
99f350sd's Avatar
99f350sd
When you turn the key to start do you here the relay bang? It should be pretty loud. If you do then check the wire going to the starter.Y/LB to see if thats getting hot. Let me know!!
Old Jul 26, 2011 | 01:42 PM
1977COACHMAN's Avatar
1977COACHMAN
1999 F250 with V10. Was at a race on Sunday - after a stop for dinner came out and truck would not start. 12V on solenoid input nothing on output when key turned. Jumped solenoid and it started right up. Put on a new starter solenoid today and same issue. Now i'm getting some other electrical 'bugs' no power windows or dome lights (but fuses are not blown?) Getting a weird sound from near/behind the fuse box under dash when key is in run position and it has that slight 'electrical' buring smell. No chime when lights on or door open - sounds like it's weak? Truck will not start in park or neutral and the reverse lights work. Suggestions?
ufvj217
Jul 5, 2016 08:05 PM
Sterling Archer
Mar 6, 2012 03:02 PM
CougarXR02
All Things Towing
13
Mar 17, 2008 12:04 PM
spartan
Jul 20, 2004 01:35 PM
dalfollo
Apr 4, 2004 10:31 PM
