Check This 47 Out
Old Jan 1, 2006 | 04:40 PM
51ford fan's Avatar
51ford fan
Check This 47 Out
Check out this Ebay auction, this is the straightest old 47 I have seen sense I purchased one back it 1970 #4601573126
Old Jan 1, 2006 | 06:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I wonder what reserve is...you generally get 1/2 the price the car/truck would be worth if it were just assembled, instead of being in pieces. Could be a hell of a deal.
Old Jan 1, 2006 | 06:44 PM
Randy Jack's Avatar
Randy Jack
That is a relly sweet looking truck. I wish I could afford to bid on it. It is beautiful!
Old Jan 1, 2006 | 07:22 PM
51ford fan's Avatar
51ford fan
The interior just blows me away, the inner door panels aren't even messed up. That truck looks like if it were put back together and cleaned up it would look darn good. Wish I could afford to bid on it myself, but I would have to find another place to live. I get enough grief on the money I'm putting into my 51.
Old Jan 1, 2006 | 07:28 PM
4tl8ford's Avatar
4tl8ford
I could almost justify buying that as a parts chaser for my Panel and Coupe projects.
I bought the coupe, its a basket case
I bought the panel as a parts chaser for the coupe cause it needed less work
If I bought the 47 as a parts chase for the other two, it just would need assembled and the motor freshened up.
Old Jan 1, 2006 | 08:23 PM
Fomoko1's Avatar
Fomoko1
Originally Posted by 4tl8ford
I could almost justify buying that as a parts chaser for my Panel and Coupe projects.I bought the coupe, its a basket case
It` thinking like that causes me more trouble than I can handle on a good day! But I still do it after all these years.
Old Jan 1, 2006 | 09:00 PM
havi's Avatar
havi
I'll have the Roast Duck
I'm thinking tax return...wife's thinking half of all i've got. How often do you see a project this clean to start with?
Old Jan 2, 2006 | 04:21 PM
286merc's Avatar
286merc
The engine is an 8BA so it is not original, I prefer the 8BA style myself.
Main problem with the 42-47 is the ugly nose! I have a 43 that will stay sitting until I can find a 40-41 nose.
Old Jan 2, 2006 | 09:40 PM
3Mike6's Avatar
3Mike6
How can you tell if it's an earlier or later flathead from the pics? I only know to look at the block/bellhousing area. I know there's something different about the dstributor, is that what you're looking at?
If in fact you have a '43, I'd suggest you rethink it...you could easily sell it (due to rarity) and come out with a strong start in a '40 or '41.
Old Jan 2, 2006 | 09:44 PM
havi's Avatar
havi
upper radiator hoses are in the front and not the center of the heads. however, I thought that's what distinguished it from 49 and later to 48 and earlier. I could be wrong.
Old Jan 2, 2006 | 10:36 PM
3Mike6's Avatar
3Mike6
Ah, I see.
Old Jan 2, 2006 | 10:39 PM
3Mike6's Avatar
3Mike6
Oh, I might add, the way I always looked at the FH V8 blocks was whether the front portion of the bellhousing was casted into the block (earlier...like pre-48) or whether the block was flush in the rear like a modern engine..i/e post '47.
Old Jan 8, 2006 | 03:04 PM
51ford fan's Avatar
51ford fan
25 minutes left reserve met on this one, its up to $6,200.00
Old Jan 8, 2006 | 08:44 PM
3Mike6's Avatar
3Mike6
Dang, it went for over 7200,...guess I should get busy and put my '42 back together?
