Water Pump Bolts Stuck
Originally Posted by rebocardo
In the FWIW category, when doing this job on a van, you might find it easier to remove the radiator and grill and use an impact tool on the bolts. You can rent an electric impact wrench from Home Depot.
hi when i replaced my waterpump i had 3 bolts snap on me and the shop had to take the timing chain cover off to drill the broken bolts out.@ thaT time i went ahead and had them replace the timing chain and gears in there.the shop told me some 1 used loctite to seal the waterpump bolts in place.(this is the reason i had 3 of them stuck in place.i do not recommend using loctite in the threads of the waterpump or any bolt threads for that matter).hope this has helped
29
01-18-2020 04:27 PM
FordmanShane
23
08-21-2012 07:16 PM
96broncoXlt
1978 - 1996 Big Bronco
30
01-08-2012 05:22 PM
T18skyguy
06-05-2010 06:50 PM
