Windshield wiper problem
Old Jan 1, 2006 | 12:16 PM
1REDWS6's Avatar
1REDWS6
Someone please help me. I feel totally incompetent today.
Yesterday, I spent the better part of the day working on the wipers of a friends truck. It is a '00 Mazda B2300. The wipers were not working. I first checked all the fuses, OK. I then got out my multimeter, and checked for voltage at the plug on the wiper motor. I have voltage at the plug. So I figured I have a bad wiper motor. I buy a new wiper motor, replace it, and it still wont work. I again checked voltage, and its still good. I then made a jumper harness to go straight from the battery to the motor. The motor turns. So if I have voltage at the plug, and the motor is good, then what am I missing? Why won't it work when they are plugged in together?
Old Jan 1, 2006 | 12:50 PM
1REDWS6's Avatar
1REDWS6
Here is a little info I forgot to add that may help trouble shoot.
The washer is working. All other accessories work, lights, horn, radio, etc. I do not have a listing of fuses or relays, but I did take each relay, and swap it with others in the truck, and I also checked all fuses with my multimeter just to make sure I didn't miss a blown one.
Old Jan 1, 2006 | 06:53 PM
Ken00's Avatar
Ken00
PINPOINT TEST A: THE WIPERS ARE INOPERATIVE
CONDITIONS DETAILS/RESULTS/ACTIONS
A1 CHECK THE IGNITION STATES — MONITOR THE GEM/CTM PID IGN_GEM
Scan Tool
NOTE: If the vehicle is equipped with a manual transmission, depress the clutch while turning the ignition switch to start.
Monitor the GEM/CTM PID IGN_GEM while turning the ignition switch through the START, RUN, OFF and ACC positions.
Do the GEM/CTM PID values agree with the ignition switch positions?
Yes
GO to A2 .
No
REFER to Section 211-05 .
A2 RETRIEVE THE DIAGNOSTIC TROUBLE CODES (DTCS)
Retrieve and document continuous DTCs.
Clear Continuous DTCs
GEM/CTM Wiper/Washer Self Test
Are any DTCs recorded?
Yes
If DTC B1431, GO to A4 .
If DTC B1432, GO to A4 .
If DTC B1438, GO to A11 .
If DTC B1450, GO to A11 .
If DTC B1840, GO to A11 .
If DTC B1342, REPLACE the GEM/CTM; REFER to Section 419-10 . CLEAR the DTCs. TEST the system for normal operation.
No
GO to A3 .
A3 CHECK FUSE JUNCTION PANEL FUSE 16 (30A)
Fuse 16 (30A)
Is the fuse OK?
Yes
GO to A4 .
No
REPLACE the fuse. CLEAR the DTCs. TEST the system for normal operation. If the fuse fails again, CHECK for a short to ground. REPAIR as necessary.
A4 CHECK THE WIPER RUN RELAY COIL CIRCUIT — MONITOR THE GEM/CTM PID WPRUN
Monitor the GEM/CTM PID WPRUN while triggering the GEM/CTM active command WIPER RLY.
Do the GEM/CTM PID WPRUN values agree with the command mode?
Yes
If the GEM/CTM PID WPRUN displays ON--- and OFF---, GO to A11 .
No
If the GEM/CTM PID WPRUN displays OFFO-G, GO to A7 .
If the GEM/CTM PID WPRUN displays ON-B-, GO to A5 .
A5 CHECK THE WIPER RUN RELAY
Wiper Run Relay
Check the wiper run relay; refer to Component Test.
Is the wiper run relay OK?
Yes
GO to A6 .
No
REPLACE the wiper run relay. CLEAR the DTCs. TEST the system for normal operation.
A6 CHECK CIRCUIT 646 (Y/W) FOR SHORT TO POWER
GEM/CTM C221
Measure the voltage between wiper run relay connector pin 2, circuit 646 (Y/W), and ground.
Is any voltage indicated?
Yes
REPAIR circuit 646 (Y/W). CLEAR the DTCs. TEST the system for normal operation.
No
A7 CHECK THE VOLTAGE TO THE WIPER RUN RELAY — CIRCUIT 63 (R)
Wiper Run Relay
Measure the voltage between wiper run relay connector pin 1, circuit 63 (R), and ground.
Is the voltage greater than 10 volts?
Yes
GO to A8 .
No
REPAIR circuit 63 (R). CLEAR the DTCs. TEST the system for normal operation.
A8 CHECK THE WIPER RUN RELAY
Yes
GO to A9 .
No
A9 CHECK CIRCUIT 646 (Y/W) FOR SHORT TO GROUND
GEM/CTM C221
Measure the resistance between wiper run relay connector pin 2, circuit 646 (Y/W), and ground.
Is the resistance greater than 10,000 ohms?
Yes
GO to A10 .
No
A10 CHECK CIRCUIT 646 (Y/W) FOR OPEN
Measure the resistance between wiper run relay connector pin 2, circuit 646 (Y/W), and GEM/CTM C221-19, circuit 646 (Y/W).
Is the resistance less than 5 ohms?
Yes
No
A11 CHECK THE WIPER SWITCH OUTPUTS — MONITOR THE GEM/CTM PID WPMODE
Monitor the GEM/CTM PID WPMODE while turning the wiper switch through all the switch positions.
Does the GEM/CTM PID WPMODE values agree with the wiper switch position?
Yes
GO to A16 .
No
GO to A12 .
A12 CHECK THE MULTI-FUNCTION SWITCH
Multi-Function Switch C254
Check the multi-function switch; refer to Section 211-05 .
Is the multi-function switch OK?
Yes
GO to A13 .
No
REPLACE the multi-function switch; REFER to Section 211-05 . CLEAR the DTCs. TEST the system for normal operation.
A13 CHECK CIRCUIT 359 (GY/R) FOR OPEN
GEM/CTM C221
Measure the resistance between multi-function switch C254-993, circuit 359 (GY/R), and GEM/CTM C221-21, circuit 359 (GY/R).
Yes
GO to A14 .
No
REPAIR circuit 359 (GY/R). CLEAR the DTCs. TEST the system for normal operation.
A14 CHECK CIRCUIT 680 (LB/O) FOR OPEN
Measure the resistance between multi-function switch C254-590, circuit 680 (LB/O), and GEM/CTM C221-13, circuit 680 (LB/O).
Yes
GO to A15 .
No
REPAIR circuit 680 (LB/O). CLEAR the DTCs. TEST the system for normal operation.
A15 CHECK CIRCUIT 684 (PK/Y) FOR OPEN
Measure the resistance between multi-function switch C254-685, circuit 684 (PK/Y), and GEM/CTM C221-22, circuit 684 (PK/Y).
Yes
No
REPAIR circuit 684 (PK/Y). CLEAR the DTCs. TEST the system for normal operation.
A16 CHECK THE VOLTAGE TO THE SWITCH SIDE OF THE WIPER RUN RELAY— CIRCUIT 63 (R)
Wiper Run Relay
Measure the voltage between wiper run relay connector pin 5, circuit 63 (R), and ground.
Yes
RECONNECT the wiper run relay; GO to A17 .
No
A17 CHECK THE WIPER HI/LO RELAY SWITCH
Wiper HI/LO Relay
Connect a jumper wire between wiper HI/LO relay connector pin 3, circuit 28 (BK/PK), and wiper HI/LO relay connector pin 4, circuit 58 (W), while turning the wiper switch through all switch positions.
Do the wipers operate?
Yes
REPLACE the wiper HI/LO relay. CLEAR the DTCs. TEST the system for normal operation.
No
GO to A18 .
A18 CHECK THE GROUND TO THE WIPER MOTOR — CIRCUIT 57 (BK)
Wiper Motor C131
Measure the resistance between wiper motor C131-3, circuit 57 (BK), and ground.
Yes
GO to A19 .
No
REPAIR circuit 57 (BK). CLEAR the DTCs. TEST the system for normal operation.
A19 CHECK THE WIPER RUN RELAY SWITCH CIRCUIT
Trigger the GEM/CTM active command WIPER RLY to ON.
Measure the voltage between wiper HI/LO relay connector pin 3, circuit 28 (BK/PK), and ground.
Yes
GO to A20 .
No
REPAIR circuit 28 (BK/PK). CLEAR the DTCs. TEST the system for normal operation.
A20 CHECK THE WIPER MECHANISM
Remove the linkage from the wiper motor.
Are the wipers free?
Yes
CHECK the wiper motor; REFER to Component Test. If the wiper motor does not pass the test, REPLACE the wiper motor; REFER to Motor—Windshield Wiper . CLEAR the DTCs. TEST the system for normal operation.
No
REPAIR the wiper mechanism. CLEAR the DTCs. TEST the system for normal operation.
Old Jan 8, 2006 | 03:57 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Check the wires at the multifunction (turn signal/wiper switch).. it's possible the are coming out of the connector, or the connector may not be plugged in all the way. Also make sure none of the wires are chaffed or broken.
I think you're getting voltage, but little amperage to the motor. Also possible you're got a bad BCM.
good luck
Old Jan 8, 2006 | 04:08 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Don't forget to also check grounding.
Old Feb 2, 2024 | 09:41 AM
Jnevrotski's Avatar
Jnevrotski
3rd Gear
Well??
Did you ever figure out what was the cause? I'm asking cause i got the same damn issue, fuse , relay, motor, (got a new one to return) multiswitch... All good like wtf??
uncleben03
Aug 17, 2015 01:15 AM
southtexasidi
17
Dec 16, 2014 09:28 AM
Grizzly4x4
Oct 21, 2014 02:57 PM
oft
17
Oct 14, 2014 01:05 PM
Rmcmorris
Aerostar
Feb 22, 2000 07:01 PM
