8CM vs. 8RT vs. 8BA heads - differences?
Old Jan 1, 2006 | 10:30 AM
Narwhal's Avatar
Narwhal
My '53 F100 239 flathead had Mercury 8CM heads on it and a C.R. of only about 5.4 I get differing stories about which heads to put back on it. One source says the 8CM and 8RT are the same, another says the 8RT and 8BA are the same. Does anyone have the straight scoop on what the volumes or CR's are on the different heads? Looking for a daily driver...
-Scott
Old Jan 1, 2006 | 12:54 PM
45ford's Avatar
45ford
Your stock bore and stroke (239 c.i.) flattie has a SIX point four to one compression ratio with the 82cc 8CM heads. With 76cc 8BA, 8RT, or EAC heads you would have a 6.8:1 CR, with 71cc EAB heads it would be 7.2:1.
Source: http://www.flatheadv8.org/compratio.htm
I don't think that boosting your compression ratio up to even 7.2 is going to give you much of a power boost. Perhaps there are other things wrong???
Mike
Old Jan 1, 2006 | 09:01 PM
Narwhal's Avatar
Narwhal
Mike
That URL was exacttly what I was looking for, thanks. 8RT it is.
-Scott
Old Jan 4, 2006 | 12:19 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The values in the chart are historically correct, but people on other sites who have measured a large sample of the Merc and 8RT heads claim their volumes are typically larger than shown in the chart. That's where the 5.4 value came from.
As soon as Narwhal raised his question about why his flatty might be down on compression and noted it had Merc heads, I suspected this situation. I've heard of it several times on different boards, and it has in all cases dropped compression very evenly down to about where his is. In one case, someone's Ford engine had somewhere along the way had one head replaced with a Merc head and the one bank was down 20 pounds from the other.
How much difference "seat of the pants" it will make is hard to say, the Merc head may breathe better with more area over the relief, who knows?!
yosemite98
May 3, 2017 09:25 AM
Ian-1949/F47-1949
Flathead V8 & Flathead 6
Jul 10, 2016 07:55 PM
jmadsen
Jul 20, 2008 10:00 AM
jmadsen
Mar 30, 2008 11:50 AM
loudfords
Aug 23, 2004 03:32 PM
