General Automotive Discussion
Fixing heated rear glass
Old Jan 1, 2006 | 08:22 AM
bodabdan's Avatar
bodabdan
Veteran: Navy
My car has a rear window defroster. The electrical terminal that connects the wire to the glass has come off of the glass. Is there a way to reattach this terminal? I am guessing that it would take a conductive glue or some soldering. I am hesitant to solder though because it may affect the plastic laminate in the glass. I really don't want to replace the entire glass just for this. Any suggestions?
Old Jan 1, 2006 | 08:56 AM
94van's Avatar
94van
I repaired mine on an Escort I once owned. I used a small soldering iron after warming the glass with a hair dryer.
Old Jan 1, 2006 | 09:36 AM
Rockledge's Avatar
Rockledge
You can try the product that Permatex makes to repair the rear window defrost tabs, you can usually get it from places like Napa or AZ, hanging on the rack with the RTV/sealant/gasket stuff.
http://www.permatex.com/auto/autogr....&item_no=21351
Keep in mind you want the tab repair adhesive, not the grid repair kit.
Old Jan 1, 2006 | 09:43 AM
bodabdan's Avatar
bodabdan
Veteran: Navy
Excellent!
Thanks.
