4.6L Noise...
Old Dec 31, 2005 | 01:43 AM
johnstechhelp's Avatar
johnstechhelp
Question 4.6L Noise...
I have this noise only at partial throttle, rpm change makes no difference...sounds kinds of like a penny being dragged across a table, really like a whisper, if i turn the air or radio on I can't hear, but not because it isn't there, it is just that quiet...I was just wondering what this may be or if anyone has ever had this "problem", I did a search on this forum and came up with nothing...BTW, it has a new EGR valve on it...It went bad and was making the same type of noise, only A LOT Louder!
EDIT: I can turn the speed control on and set it and the noise mysteriously goes away...
John
2005 F150 SuperCrew 4.6L V8
Old Jan 1, 2006 | 04:53 PM
LxMan1's Avatar
LxMan1
Sounds like a possible vacuum leak somewhere. You might check the PCV hose elbows.
Old Jan 13, 2006 | 04:13 PM
johnstechhelp
sorry i haven't got back to you, been unable to check under the hood...
i checked it out, and the pcv valve almost seems like it is loose (give is about 1/16ths of an inch), there is also oil around the outside of it, where the elbow connects to it...
celliott
2009 - 2014 F150
Feb 2, 2011 01:30 PM
howsthat1959
Jan 16, 2007 02:49 PM
johnstechhelp
2004 - 2008 F150
Jan 4, 2006 07:55 PM
NASCARTruckDude
Modular V8 (4.6L, 5.4L)
Aug 4, 2003 10:30 PM
