help me identify my automatic transmission
Old Dec 30, 2005 | 11:49 PM
3scottsbaker's Avatar
3scottsbaker
Question help me identify my automatic transmission
Here's what I know about it - the transmission is bolted up to a 1974? 351 Cleveland - the yoke has 31/30 splines on it - the pan has 14 bolts - the pan measures 8.5" x 11.5" - the pan is rectangular except for a 1/2" x 2.0" recess on the front left corner - I think it might be either a C6, FMX, or AOD - the numbers that i can make out that are cast into the transmission is possibly D2AP7008AB - can anyone help me?
Old Dec 31, 2005 | 02:04 AM
Boss_358's Avatar
Boss_358
If the case is all one peice of aluminum then it is a C6. If the Bellhousing is aluminum, the case is cast iron, and the tailshaft housing is aluminum, it is an FMX. THe only way it can be in AOD is if someone swapped it behind that engine. AOD transmissions usually have "METRIC" stamped into the pan as well.
Old Dec 31, 2005 | 05:21 AM
stuart1's Avatar
stuart1
You posted on another forum and were given the correct information.
It is an FMX.
Old Dec 31, 2005 | 06:26 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome 3scottsbaker, to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
