just rebuilt my first transmission c6 in my 1985 f150 4x4
put everthing in truck hooked everthin up filled with fluid
started truck up let it run for a few miniutes to get fluid moving
put in gear and motor dropped in rpms like it wanted to move but the rear wheels didnt move checked vacume line to regulator
also checked line pressure and was bouncing between 60 to 80psi
is that enough line pressure ?
any ideas of what else it could be would really help?
thanks
put new clutch plates springs seals rebuilt pump new o-rings cleaned out valve body replaced output shaft (tranny was a 2 wheel drive)pressure regulator thanks
dont rememder what the end play was off hand it has been awhile since I had did it but it was within specs
I will pull the pan and air check it that was going to be next thing wanted to get other opinions thanks
