swapping rear suspention
Old Nov 17, 2001 | 09:58 PM
cakewalker's Avatar
cakewalker
Will a 1973-79 F250 rear suspension bolt directly in place of a 1977 F150 rear suspension? along with the heavier rear end?
Old Nov 18, 2001 | 12:32 PM
ecarter50's Avatar
ecarter50
If the F250 is 2wd the frames should be the same width but the springs are wider so you will have the change the spring hangers that are riveted on and reinstall with grade 8 bolts.
Old Nov 18, 2001 | 08:45 PM
Franklin2's Avatar
Franklin2
