Pulled the head - wrong one!
Old Dec 31, 2005 | 08:53 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
Do you know what the compression ratio of the motor goes up to when .060 is shaved of the heads? Lets say the motor is all factory and all I am doing is shaving a set of 8RT or 8CM heads.
Originally Posted by 286merc
8RT heads are no better than the 8CM; true CR in a 239 comes in around 5.8. 8BA and EAC are close to each other and EAB are the best for compression.
Any flathead can easily be cut up to .060 to clean up the surface and/or raise the CR a bit. Stock 8BA volume is 76cc and the EAB is 71cc
Old Dec 31, 2005 | 01:21 PM
Narwhal's Avatar
Narwhal
What's that in psi?
-Scott
Old Dec 31, 2005 | 07:40 PM
286merc's Avatar
286merc
Originally Posted by Narwhal
What's that in psi?
-Scott
Thats an easy one. With atmospheric pressure being 14psi at sea level it is a simple ratio. Example: taking the original compression reading of 75psi divided by 14 = 5.4cr which is close enough for government work based on my initial calculation of the 8CM heads on a 239
Of course it will be less in Denver which was why Ford offered Rocky Mountain heads back in the 30's.
Approximately 7.3
Old Dec 31, 2005 | 07:56 PM
Narwhal's Avatar
Narwhal
So you're saying that my compression of about 75 psi is about what should be expected with 8CM heads? What about with 8RT or 8BA heads? Is there a resource that lists stock volumes for the different heads?
-Scott
Old Dec 31, 2005 | 08:56 PM
286merc's Avatar
286merc
.................. What about with 8RT or 8BA heads?
That was answered 2 posts ago
Yes and no. I didnt trust the data in some books since they didnt agree with each other so I cc'ed my own
-Scott[/QUOTE]
Old Jan 1, 2006 | 02:16 PM
AXracer's Avatar
AXracer
Before you go milling heads, be sure to accurately measure the piston top to deck height, since you said it looks like the engine has had some machining, it'll possible/likely the deck was cut at the same time and/or higher compression pistons added.
Old Jan 1, 2006 | 03:46 PM
Narwhal's Avatar
Narwhal
Thanks, good point.
WhySoSerious
New Member Introductions
Oct 6, 2014 10:21 AM
npccpartsman
Sep 20, 2013 06:43 AM
Narwhal
Dec 20, 2005 09:05 AM
