Motorcraft Plugs
I think people have found them in Walmart, and other brand-name auto parts stores.
Denny
Thanks.
I can't begin to tell you how many times this has been gone over. Many MANY people reporting misfires and generally bad-running modulars after changing to another brand plug. Switch back to Motorcraft, BAMMO. Back to running like new.
Whether that's the aftermarket manufacturer's cross-reference being off on the heat-range, or something not quite right w/the plug for the modulars, I don't know. But if their cross-reference is wrong, they haven't done their homework anyway, so I'll gladly stay away from anything else.
Caveat: I never, ever, bought Motorcraft anything for my other Ford's. I figured if it broke, why by an original part and have it do it again anyway? I'll still feel that way about water pumps (as long as the aftermarket isn't too cheap, which is a bad thing), starters, you name it, but not plugs after being on this site for so long (and other sites too, like the t-bird/cougar MN12 sites).
Side story: Triumph spec'd Champion plugs on their TR7 2.0L slant-4, from '75 through '81 (all years). I used to work on them on the side through a mechanic friend who didn't know the cars and passed them on to me. Someone would come to my house with Bosch-platinum/Autolite/NGK plugs in the motor and say it needs a valve-clearance adjustment, or maybe there's a burnt valve, or carb rebuild or something pretty major because a "real" mechanic had told them that after not being able to find anything simple. I'd go into my garage and find a dirty set of Champion plugs, clean them up and regap them, swap them for the Bosch's (or whatever) and the car ran fine.
One guy was so happy he threw me a $100 tip. I told him the cleaned up plugs I used would last about 5K or so, and get them done the next oil change ... I talked to one guy a few years later and he said they were still in the car years later. He figured if it ran right, why mess with it?
Now, you'll say "Champions? They're crap"... nope, but enough people have had problems with them when using them in cars that are NOT SPEC'D for Champions, and have problems, and blame them on the brand instead of the fact that those plugs just weren't compatible with the car.
Now, you'll say "What? I've run all sort of plugs in my cars and they all work fine". Well, non-Motorcraft plugs work "fine" for some (if not most) people. But we here have seen more cases of people with misfires with non-Motorcraft plugs than even I can imagine.
Not to shove the "new user" thing down your throat, but there are too many cases of non-MC plugs screwing with your head.
had installed Bosch, replaced the Bosch with Motorcraft, and it hasn't had a mis since! My gas Mercedes, however, runs great with Bosch plugs!!!
