Electric Choke
Old Dec 30, 2005 | 12:09 AM
BigBody's Avatar
BigBody
Electric Choke
I've posted about this before. I finally got around to hooking it up. I did it a diff way then everyone recommened and just wanted to see if it is okay. My friend thought it would work and I just wanted to get it done. WE had isntalled my lift earlier so i was pretty tired.
I ran the wire straight to the battery but put a fuse(30) between the battery and the choke. Is this safe?
I turned the truck on only for a few mintues to move it and park it for the night. It was idling higher like it was tyring to warm up so I think it was working. I'll be able to test it out more tomorrow when I actually go to drive it.
LMK.
Thanks,
Kyle
Old Dec 30, 2005 | 12:11 AM
BigBody's Avatar
BigBody
Oh ya, its on a 1977 f-100 4x4 with 400 that has aftermarket intake and 4 barrel carb. I believe intake is holley but not sure what carb is.
Kyle
Old Dec 30, 2005 | 12:14 AM
ford390gashog's Avatar
ford390gashog
so that means the choke is running all the time! it will drain the battery or cause a fire. when running there is a metered vacuum to cool the choke, with it off it will get way to hot.
why not just do it right? and hook it to the stator terminal on the alternator?
Old Dec 30, 2005 | 12:18 AM
BigBody's Avatar
BigBody
I haven't it ran it long so I can fix it when I get up.
Whats the starter terminal? Is that were the postive of the battery goes to a silver box and then to the starter? Where do I hook it on alt? I just wasn't sure where to hook it up at.
Kyle
Old Dec 30, 2005 | 12:20 AM
ford390gashog
you may have to pull the alternator, the terminal is labeled "stator"
Old Dec 30, 2005 | 12:21 AM
BigBody's Avatar
BigBody
Any chance I could see or find a pic? Could you describe it? Is it on back side or what?
Old Dec 30, 2005 | 12:32 AM
ford390gashog
yes its just a post on the back of the alt next to the battery post.
Old Dec 30, 2005 | 12:35 AM
BigBody's Avatar
BigBody
Alright, thanks! I'll make another attempt at it in the morn.
Thanks again!
Kyle
Old Dec 30, 2005 | 12:40 AM
ford390gashog
sure no problem.
Old Dec 30, 2005 | 09:58 AM
BigBody's Avatar
BigBody
Here's where I hooked it up too. I hope this is what you were talking about.
https://www.ford-trucks.com/user_gal...=94773&width=0
LMK.
Thanks,
Kyle
Old Dec 30, 2005 | 09:59 AM
BigBody's Avatar
BigBody
I'm not sure if my alt i same as pictured. All mine had was bolts sticking out with nuts. So, I pulled the lower bottom nut off and put my wire on then nutted it back.
Old Dec 30, 2005 | 11:32 AM
BigBody's Avatar
BigBody
Well apparently thats not it b/c now it wont start. I unhooked it and it still won't. Must of killed the battery or something.
Any ideas?
Old Dec 30, 2005 | 12:10 PM
BigBody's Avatar
BigBody
Need help fast! Its stuck in the driveway and wont turn over.
Old Dec 30, 2005 | 12:26 PM
BigBody's Avatar
BigBody
Its not the battery.
Old Dec 30, 2005 | 12:46 PM
53fatfndr's Avatar
53fatfndr
Go back to square one and get everything hooked up except the carb, get your engine to turn over then mess with the e-choke.
I believe, all you need is a "keyed" hot wire for your choke. Check the electrical forum, I know there are a few threads in there on wiring an electric choke. If you need more help, just post back.
