Electric Choke
Old Dec 30, 2005 | 12:51 PM
BigBody's Avatar
BigBody
What do you mean everything hooked up except the carb?
I put everything back how it use to be. No eelctric choke, etc... It won't even click. Does it look like i fried a fuse or something big like an alt or starter?
For after I get it running, I belive I read somewhere that I can buy a fuse tap, and tap it into the heater fuse on the fuse panel and that should work. That sound right? Should I put another fuse between heater fuse and choke?
Old Dec 30, 2005 | 01:00 PM
53fatfndr's Avatar
53fatfndr
What do you mean everything hooked up except the carb? Don't hook up the e-choke right now.
It won't even click. Does it look like i fried a fuse or something big like an alt or starter? Possibly, but I don't know if the starter is a fused circuit for that year of truck. It could be the starter relay, I'm not really sure. However, check all your wiring and fuses then go from there.
For after I get it running, I belive I read somewhere that I can buy a fuse tap, and tap it into the heater fuse on the fuse panel and that should work. That sound right? Should I put another fuse between heater fuse and choke? I can't help with this, sorry. I went with a wiring loom that has a dedicated e-choke circuit that is hot only when the key is on, I believe.
Old Dec 30, 2005 | 01:47 PM
Bill_Beyer's Avatar
Bill_Beyer
If you left it hooked up overnight then you drained the battery completely. I'd take it out and try a different battery or have it tested and charged.
Old Dec 30, 2005 | 05:36 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
That STATOR terminal on the alternator has a output of 6.95 to 7.07 volts which was ok with Ford's early electric chokes in the 60's. Todays replacement carbs / electric chokes require 12 volts to function properly. They only draw 4 1/2 to 6 amps so a hot on ignition on terminals at the fuse box will work, just add a 10 amp fuse in line. The bad thing with this setup is if ignitions on a cold motor but not started the choke will open as well the heating element overheats because the vacuum passage isn't pulling air to cool the element. What I did was add a 6 volt relay that energizes from the stator terminal, that controls 12 volt power to the electric choke. This way the choke only recieves power when the motors running.
.....=o&o>.....
Old Dec 30, 2005 | 11:37 PM
BigBody's Avatar
BigBody
Got the truck running. But seems to me there is no good way to hook up the electric choke on aftermarket carbs.
Kyle
Old Dec 31, 2005 | 12:08 AM
53fatfndr's Avatar
53fatfndr
Kyle
If you have a Holley carb, search their website. I would think they would have directions that might even have a few suggestions as to power sources in them as well. Also, check the electrical forum on this sight I have seen a few threads in there in the past for wiring up an electric choke.
Old Dec 31, 2005 | 12:55 PM
Bill_Beyer's Avatar
Bill_Beyer
Run a wire from the accessory terminal on the fuse panel to the electric choke. It should be a switched 12V source which has a 10A fuse. I did it on my 70 XL when I installed the new BG carb. It works fine. You can either run it through the hole in the firewall that the rest of the wires run through or as in my case find an unused plugged hole. I bought a new grommet and some black corrugated loom cover and it looks factory.
