Doughnut Gasket
Old Nov 19, 2001 | 10:02 AM
classic79's Avatar
classic79
Doughnut Gasket
Old Nov 19, 2001 | 08:53 PM
77 steve's Avatar
77 steve
Doughnut Gasket
Any suggestions on how to remove the old doughnut gaskets from the manifolds without damage to the manifold. I dropped the collector pipes and the gaskets are hard as a rock and seem to be stuck to the manifolds pretty good. Thanks for any help.
Old Nov 19, 2001 | 09:06 PM
Mil1ion's Avatar
Mil1ion
Doughnut Gasket
I used to use Vise Grips until they crumbled away,if that doesn't work try a hack saw nipping out an 1/8 of it then grab and pull.
Dennis
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Nov 19, 2001 | 09:07 PM
StockMan's Avatar
StockMan
Doughnut Gasket
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
On certain manifolds, the "doughnut" was part of the casting or "built-in" if you will, thus not removable. I suspect that is what you have here.
[/FONT]
https://www.ford-trucks.com/dcforum/User_files/StockMan/flag.gif[br][FONT COLOR="#ff0000" SIZE="+2" FACE="Bassett"]Stock Man[/FONT]
[FONT COLOR="#0000ff" SIZE="+1" FACE="Tahoma"]
[LINK:www.ford-trucks.net/users/stockman|Stockman's Club FTE Site]
[LINK:www.67fordtruck.com|1967 F-Series Registry ( www.67fordtruck.com )]
Old Nov 20, 2001 | 07:52 PM
77 steve's Avatar
77 steve
Doughnut Gasket
I suspect you are right Stockman. I have developed a leak and in the past been able to loosen the exaust move it around and tighten it up again to stop the leak. Not this time. I almost think the opening of the exhaust has gotten larger over the years not allowing it to butt up correctly with the manifold.
Old Nov 20, 2001 | 10:16 PM
BigBrownTruck's Avatar
BigBrownTruck
Doughnut Gasket
I've had them be stubborn but abusing them w/ vise grips or channel locks eventually gets them loose if they really are donut gaskets. Often I end up mangling it to the point of breaking through part of it and then it's easy.
BBT
Old Nov 21, 2001 | 05:40 AM
StockMan's Avatar
StockMan
Doughnut Gasket
I should have mentioned that the original doughnuts were made od cast iron and the replacements are a composite metal-fiber deal. These type are usually locked into the exhaust pipe by the design of the pipe. The pipe is flanged around the outer edge of the doughnut and has a center pipe that fills out the center of the doughnut. The doughnut usually will stay with the pipe due to this design. That's why I suspected this was not a removeable doughnut-type gasket. If it is, the methods described will easily remove it. Good luck.
[/FONT]
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
