Sponsored by: Auxito
4.6 liter Question
Old Dec 29, 2005 | 10:44 PM
preppypyro's Avatar
preppypyro
4.6 liter Question
Hey guys, I have been doing some research on the romeo and windsor 4.6's. Just about every thread that came up has basically no info on the differences, if any, between these engines. About the only thing I have found out is that the windsor is supposedly a tougher engine. Does anyone actually know if these two engines are swapable? Are they actually different? I am just curious to find out what people know, if anything, about the differences!
Old Dec 30, 2005 | 01:49 AM
97Centurion's Avatar
97Centurion
Rub my Belly
The valve covers are different and bolt up different. I was thinking the bolts on the flywheel was different but not sure about that. Also I was thinking that the romeo had a smog pump, atleast the pic that I have looks like it has one.
Old Dec 30, 2005 | 06:00 AM
preppypyro's Avatar
preppypyro
Hmm so I wonder If the windsor is tougher, will they bolt up in place of a romeo..? Anyone else have any thoughts?
Old Dec 30, 2005 | 12:41 PM
LxMan1's Avatar
LxMan1
Windsor has 8 flywheel bolts, the Romeo has 6. The timing chain assemblies are also slightly different.
Old Dec 30, 2005 | 01:56 PM
matt_97xl's Avatar
matt_97xl
Some say the Windsor is better some say the romeo.Truth be told i think the same basic spec went out to two different engineering firms who put a little of their own spin on the design.Both engines are within fords specs so...
What you need to look at is faults in the mass manufacturing of the motors .I'm biased since i own a Windsor live here and personally know the people that built the line.Ive also worked on the front clip of the 04 and up.It really depends where your rig was manufactured as far as motor you get for the 4.6.I don't think Romeo builds the 5.4.
Oakville got the Windsor and i think Kentucky got the romeo most of the time.
Due to logistics,just in time delivery and production hiccups you could still have an oakville build with a romeo and visa versa.
Old Dec 30, 2005 | 01:58 PM
matt_97xl's Avatar
matt_97xl
Ill check if thy are swappable but i think they bolt up to the tranny differently not sure.But even Windsors can be a problem with year to year variances.Nothing is impossible though.
Old Dec 30, 2005 | 09:50 PM
preppypyro's Avatar
preppypyro
Sounds cool thanks for the input guys!
Old Dec 30, 2005 | 11:11 PM
fbodyfan's Avatar
fbodyfan
This oughta help: http://www.mustangandfords.com/techa...ufp_0509_swap/
and http://www.mustangandfords.com/techa...ufp_0510_swap/
Very good quality info in both of those articles.
Old Dec 31, 2005 | 10:11 PM
peppermrj's Avatar
peppermrj
Post
This article from an engine rebuilder details the differences between the two and also the years. http://www.babcox.com/editorial/ar/eb40228.htm
Also you might enjoy this somewhat biased article about the Romeo plant.
http://www.modularpower.com/engine.htm
Old Jan 1, 2006 | 10:43 AM
preppypyro's Avatar
preppypyro
Thanks for the links guys, very helpfull.
