Well had a few things to over come during the process,but all looks and runs fine, thanks to all over the past month on the rebuild. You guys are great take a look a my gallerie for some pics.
Last question, set the timimg a 6btdc was told to plug the line out off the dizzy it did but it didn't make a difference i have convert to eletronic ignition i guess that would make a difference.
thanks to all, i will tell everyone that ask about the truck where i got the info
If I'm reading what he's saying correctly..he blocked of the line coming out of the dizzy... there is no vaccum on that the vacuum is coming from the carb base fitting..you want to block the line off that connects to the vac advance on the distributor while the truck is idling at normal temp correct ?
redmanbob your right on track with me, didn't see much difference when trying to do the timing pulged the line and unpluged it timing stayed at the same make.
