I have a 1982 F-150 4x4 with a 351w in it. My transmission recently crapped the bed on me and i have been having trouble locating a replacement. My current tran is a T-170 SROD. It has an aluminum case with a 10 bolt cover with the shifter in the rear tail-housing. It is 3 spd with and OD (so 4 spd altogether). My question is does any body know what transmissions are compatible for this year. Any help with different years and/or models will be greatly appreciated. I figure the more models i search for the better chance i have of finding what i need. thanks.
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
I havent found any where to get parts for the SROD I have. I recomend get a differnt tranny. I spent a wasted week end bouncing between differnt tranny shops and they all said the same thing. It was fords cheap excuse for a tranny and was discontinued. A rug tranny side linkage will work and it lined up through the floor.
