4x4 Conversion!
This is my first post here, seeing as today my father was given an 1995 F250 5-speed Turbo Diesel to work out of. The only problem is that it's 2-wheel drive.
Now I honestly tried the search feature and sifted through threads for about 20 minutes before posting so be nice! The question of the day is would it be feasible to convert it to a 4x4? Now I work on a lot of cars, but I really don't know much about Fords in general (other than this truck can go 0-60 faster than my accord!!!)
It looks like there's room to chop the driveshaft, put in a transfer case, and run an offset axel to a solid axle on the front end. Just my thoughts....
Thanks
There's an article in the tech articles section here on FTE that goes into what you have to do for an F-150. Just keep in mind that you'll be going from coils to leafs in the front and you should have an idea of what it takes.
Thanks
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Feasible, yes, it is possible. Cost effective, no, not unless that 1995 has less then 150,000 miles on it. Otherwise you would be ahead money by just buying one 4x4 on E-Bay and selling that one 2x4.
IF I was going to spend all that time and money converting it I would not bother with anything less then an older Dana 60 for the front. That engine puts out at least 400 pounds of torque, weighes a lot more then even the 460 (1200-1400 pounds?), and with large tires it will make short work of lighter duty axles.
The trucks have the front axle diff. on the driver's side so a lot of mail order sources (ex. Boyce) will not have an axle for your truck. Plus, the axle itself will probably sell for at least $1000, then you have to regear it, etc.
