General Automotive Discussion
Injector balance test
Old Dec 28, 2005 | 09:19 AM
maa139's Avatar
maa139
Anyone know how to do an injector balance test WITHOUT a fuel injector and harness tester? I have the fuel pressure gauge, but need to know of a way to isolate each cylinder...
Thanks.
Matt
Old Dec 28, 2005 | 01:32 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
The ECM in some Fords will allow you to enter into a cylinder balance diagnostic mode using your scan tool. What happens is each cylinder is sequentially dropped via killing the injector and the change in engine speed is noted. Dropping a cylinder and with a resulting engine speed change much more dramatic (ie, minimal change) than the others is flagged; I don't recall the percentage change in engine speed that throws up the flag. While this does not directly confirm a weak injector, you should be able to swap a suspect injector with a cylinder that passes the test then repeat the test. If the problem follows the injector, you found it.
Old Dec 28, 2005 | 03:32 PM
andym's Avatar
andym
This is an OBD-II only feature, as far as I know.
Old Dec 28, 2005 | 03:49 PM
CowboyBilly9Mile
Allegedly it existed on my old 94 Ranger 4.0 EEC-IV; I never invoked the test (never had the need, thank God).
Old Dec 29, 2005 | 10:23 AM
MustangGT221's Avatar
MustangGT221
Doesn't have to be OBD-II. Any EEC-IV SEFI vehicle will perform the test. After the KOER test, you can stab the throttle and it'll go into that test format. It doesn't work on MEFI but it works on SEFI (multiport vs sequential).
79CEEJAY
Apr 6, 2013 12:06 AM
lhud
25
Sep 8, 2011 09:31 PM
danielwd
1983 - 2012 Ranger & B-Series
Jan 2, 2011 10:18 PM
Unglued
WTB - Parts & other
Nov 28, 2010 08:20 PM
MAHinton
Oct 12, 2003 11:26 AM
