what engine is this? (Mercury)
Old Dec 28, 2005 | 07:03 AM
Narwhal's Avatar
Narwhal
I have a Mercury engine in the 53 F100 I'm rebuilding. The compression is low (75 lbs. +/- 5 lbs) per cylinder. I'm going to test it tomorrow by squirting oil in the cylinders and see if the compression changes. I'm assuming a rebuild of some degree will be in order. My understanding is that this is basically a stroked 239 with slightly different heads to adjust compression.
How do I tell what year engine it is since it is not the engine that shipped with ? I have photos in my gallery of the numbers at the rear of the engine (21 and 57P 4) and the engine. It appears to be 24 bolt 8CM heads. Any information you can give me on this would be appreciated. The engine runs, but weakly. What information do I need to know to order head gaskets, etc.?
-Scott
Old Dec 28, 2005 | 09:44 AM
mtflat's Avatar
mtflat
That's your garden variety 255 ci Merc flathead if the heads haven't been swapped. You can't tell for sure until you pull the heads and measure the stroke. (4" stroke is merc, 3.75 is ford) Both use the same parts except for pistons and crank.
It will probably run forever with the compression you have - flatheads are amazing engines. Fresh rebuild should be 110.
All you need to know to order rebuild materials is it a 49-51 8CM (or 52-53 = EAC) None of the other numbers you found mean anything. I've found parts counter guys choke on a range of numbers sometimes. If you run into that, tell them its for a 51 Merc car.
My first suggestion would be for you to contact Red's Headers, CA or Patrick's Antique Auto Parts, AZ for the right parts the first time. Both are top notch flatheaders and will treat you right.
Old Dec 28, 2005 | 09:57 AM
Narwhal's Avatar
Narwhal
Heads say 8CM, so that's solved...
I understand the crank difference (stroke). Why are the pistons different - pin placement? I think that the heads are different as well.
Cutting to the chase, can I use the standard 239 head gaskets? I'd like to pull the heads to check the valves, etc. and de-carbonize everything.
Thanks for the information.
-Scott
Old Dec 28, 2005 | 11:06 AM
mtflat's Avatar
mtflat
-Scott
8CM heads are some of the largest volume heads used in order to keep the CR at 6.8 with the longer stroke. Piston pin placement is 1/8" higher on merc pistons to make up for the longer stroke of the crank. Con rods are the same for both F 'n M.
Short answer is yes, 239/255 use the same head gaskets.
Old Dec 28, 2005 | 11:13 AM
njf207's Avatar
njf207
The only thing I know is that the engine was used untill 53' and then in 54, they went over head valve sorry I can't help you more
Old Dec 28, 2005 | 11:38 AM
oldmercury's Avatar
oldmercury
Sir: "...a rebuild of some degree..."??? How many times have I naively gotten into an old engine wishing for "some degree of a rebuild". On flatheads especially, there can be no such thinking, in my considered experience, as you seem to imply. Think you can get away without boring it out? Replacing cam? replacing valve components? unbolting the heads without a bolt or two snapping off? Think again. I would plan for a complete rebuild and, depending upon varying factors such as parts acquisition & if your machinist has a two thousand dollar boat or motor home payment coming up, sinking some big bucks into that block. Otherwise, just fire it up and see if there are any deleterious issues such as ominous noises or oil leaks, overheating, etc. Good luck.
Old Dec 28, 2005 | 11:51 AM
blueknight44's Avatar
blueknight44
Bronx Tale
My first vehicle was a 53 Ford with a flathead 8, just do regular maintainance and use it!
Trouble will find you elsewhere!
Drive that great car of the best years of "Rock in Roll"
From Conners Street, New England Thruway,
"The Bronx New York"
White Castle Boston Post Road
Yankee Stadium
Now in Boulder City Nevada
Old Dec 28, 2005 | 01:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Given the low compression, I'm wondering if someone hasn't put Merc heads on a Ford engine. A lot of people mistakenly assume that all Merc parts result in a performance increase on a Ford engine. The Merc heads actually have a larger combustion chamber to compensate for their larger displacement (to give the same compression ratio). I wouldn't be surprised to find it's a 239 with 8CM heads, and just needs the right heads to restore compression!
Old Dec 28, 2005 | 01:17 PM
Narwhal's Avatar
Narwhal
Can I tell without pulling the heads if it's a Ford or Mercury block?
Please see gallery for pics of rear of engine block showing numbers.
-Scott
Old Dec 28, 2005 | 01:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
What kind of carburetor was on it? Was it a "teapot"? (Merc style carb) or the typical Ford/Holley model 94? While nothing but a check of stroke will absolutely verify it as a Merc, there are some other clues; What does the intake manifold have for a casting number? Is the oil pan a truck style (with large round clean-out section)? Also look on the intake manifold block surface, right rear, for some punched-in marks. They can sometimes be de-coded. On the other hand, all of these parts interchange. If you want to measure the stroke without pulling a head, try dropping the pan. You can measure from down there (on a cylinder) and clean out all the crap at the same time!
Old Dec 28, 2005 | 01:27 PM
Narwhal's Avatar
Narwhal
It was a "Ford" labeled Holley 94 carb, but the air horn doesn't match the oil bath air filter - I've had to shim it out about 1/16" to fit. The rest I'll have to check on.
Hard to tell what's original and what's not.
-Scott
Old Dec 28, 2005 | 02:40 PM
4tl8ford's Avatar
4tl8ford
The only way to tell is by measuring the engine stroke.
The blocks are identical (within reason)
The difference is in the Crank and the pistons.
Everything else interchanges.
Unless you pull one out of a barn with o miles, the stickers still on it, and unworn (dry rotted) tires. It needs the heads pulled to be sure.
Old Dec 28, 2005 | 03:40 PM
3Mike6's Avatar
3Mike6
I'm wondering if you can pull a plug, make a plastic gauge and put it in the plug hole, and turn the engine over to get a stroke check?
Old Dec 28, 2005 | 03:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Mike, Can't really get a clean shot down the cylinder. Like I said, pulling the pan is not hard (on the trucks) and you can measure from the bottom of the skirt to the bottom of the cylinder bore (I can't remember if the skirt projects past the cylinder at BDC). Plus you get to see what shape everything else is in, maybe pull a rod cap, main cap, oil pump and screen, etc. No cost except for a gasket.
4TL8, I'm not sure I'd trust that one either!
Old Dec 28, 2005 | 03:57 PM
3Mike6's Avatar
3Mike6
I wasn't sure if it was like the Mopar FH 6's I have or not.
I'd be the guinny pig on my FH V8's, but both are stuck and soaking in diesel. 5 gallons in each poured through the plug holes and intake...funny thing is there's none leaking on the floor.
Tells me at least the pan gaskets are still holding
