Traction Lock or not?
Old Nov 16, 2001 | 12:27 PM
petem's Avatar
petem
My '76 F250 4x4 spun like a conventional differential when I jacked up the rear end. Shouldn't a 4 wheel drive have posi? Thanks!!
Old Nov 16, 2001 | 01:03 PM
dfisher1's Avatar
dfisher1
Pete,4x4s do not have posi traditionally. Posi is a dangerous option to deal with during the winter on icy roads. 4x4 trucks with wide tires are even more prone to sliding and posi makes it worse. Now if your serious about getting off road, then posi is what you need, in the back. I found they're a little hard to steer with a locker up front. To each his own.
Good Luck, Have Fun,
KingFisher
Old Nov 16, 2001 | 01:50 PM
78f250's Avatar
78f250
I think he is really meaning limited slip.....
Old Nov 16, 2001 | 02:20 PM
Like M. Fords's Avatar
Like M. Fords
"Posi" is short for Posi-Traction which was used only by GM. It was a limited slip unit, but somehow the name has been turned generic reffering to just about any type of traction adding device used in all brands of vehicles.
Old Nov 28, 2001 | 09:26 AM
dzjammer's Avatar
dzjammer
Old Nov 28, 2001 | 10:26 AM
georgiafordman78's Avatar
georgiafordman78
Every 73-79 F250 axle I've opened has Trak-Loc. From my experiences at the mudholes in my 78 F250 4x4, the trak-loc set up works get. I get true 4 wheel drive, not a common 3 wheel peel! I personally like the trak-loc, not bad for factory equiptment!!
