The lights on my steering wheel for the cruise control are very intermittant. At time the left side lights work or the right side lights work, or both work, or none work..
I took it to the dealership that I bought it from and they actually told me that there are no lights in the steering wheel (ficken idiots! ).. Go figure...
Must be a common problem as I have had this issue on two Explorers myself. From what I understand there are no actual bulbs or something simple like that you can replace in these lighted cruise controls, at least on my 1998. The fix is installing new cruise control modules, (the buttons, lights, the whole works) on the wheel. The last I checked, and it has been a long while, I think the modules ran around 40 bucks each, but like I said, it has been a while. I never replaced mine, just live with no lights on those cruise controls. Also, if I remember correctly, replacing them involves temporarily removing the steering wheel airbag, something I really didn't want to deal with.
JD
I'm not a big fan of removing the steering wheel either, especially with air bags involved but It is really annoying and my **** tendencies are getting the best of me.
Seems wierd that there would be no lights in the wheel it self.. Are there some kind of fiber optic light tubs comming from the cruise control box and that is what makes the wheel light up?
It is the modules that have the "lights" in them and they are actually not part of the wheel (I'm talking 1998 Explorer here) They are separate, self-contained plastic electronic cruise control modules that can be unplugged from their electrical connectors and replaced after you take part of the steering wheel apart. There are no bulbs to replace or fiber optics outside of these modules. To replace the 'lights" you have to replace the whole module. These are two separate modules. ON/OFF on the left. And the other cruise control functions on the right. One on either side of the center of the steering wheel. In the Middle and above them is the airbag module. My lights are out on these too, but it didn't replace them because:
1. I know where the controls are without having to look at them
2. They are not real cheap
3. It requires removing the airbag
4. The new modules may not work any better.
Hope that helps
JD
You can get the bulbs separate. Here are their numbers:
I will defer to your expertise since I have never taken these modules out and looked at them. I was just going by what it said in my repair manual and what the dealership told me. I guess they just wanted some more of my hard earned bucks. LOL Thanks for the info.
PS: If anyone has installed these bulbs into these cruise control modules before how difficult is it? Does the module come apart easliy and how? Does it require working on the circuitboard at the componet level or do the bulbs just pop in. And any other suggestions and hints would be helpful.
Thanks in advance
JD
It took me a while to find the bulb numbers. It is not a public known fact they have bulbs that can be replaced - even by some Ford part centers. I have the Ford shop manuals - and they do not even lists the bulbs - only say to change the module.
I've changed them before. Pretty simple. I took the airbag off the steering wheel just so I didn't hit it or something happen while I was working around it. Then I took and pryed the controls apart. The bulb just twists into place. Reassemble and you're good to go...
Excellent! I'm a tinkerer at heart, so maybe I'll brave the airbag removal and try what you say. Particularly if the bulbs just twist in. If I can't make it work, well, I haven't lost much in terms of money and will probably learn some useful things in the process.
Thanks much
JD
Sounds pretty simple.. But I don't believe the bulb is my problem as they work from time to time. It must be the modules.. Any one else experience the intermittant thing?
I have also replaced the bulbs in the Cruise control switches. A word of WARNING!!!. Before removing the airbag, disconnect the battery and leave the vehicle alone for some time (I left it 30 minutes) to allow any capacitors to discharge. The airbag fixings are under the small plastic covers on either side of the steering wheel centre boss. The switch modules can then be removed and unplugged. Carefully prise the module apart. The bulb is a bayonet fit.
Best wishes. Happy New Year. Thanks for the photos CobraXP.
