Diesel Motor Question?
Old Dec 27, 2005 | 09:18 PM
LRE F150's Avatar
LRE F150
OK i know this has been discussed and im sorry for beating a dead horse but will a powerstroke fit in the older 250's and 350's? like into a 79 maybe?or even the late 80's trucks?
Old Dec 29, 2005 | 07:52 PM
nevrenufhp's Avatar
nevrenufhp
Yes they do. I've seen a pic of one in a crew cab '74 F250.
Old Dec 29, 2005 | 09:30 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The fit is not the problem.
The computer and wiring that has to be done to make it run is another story though.
Nothing that can not be done, but it will take a while to do it.
Old Dec 30, 2005 | 11:21 AM
pfogle's Avatar
pfogle
You basically need a donor TRUCK. A complete truck with all the wiring and everything. Then you will need to adapt the newer wiring harness to work in the old truck.
Old Jan 1, 2006 | 03:59 PM
Matts72's Avatar
Matts72
A 7.3 IDI with an aftermarket turbo is a much more feasible swap. Powerstrokes and newer Cummins (24V) have a rediculous amount of wiring.
Old Jan 2, 2006 | 05:26 PM
LRE F150's Avatar
LRE F150
Wiring is no problem I love it!I jus didnt know if it actually fit..What about motor mounts and trans mounts,and wat trans is everyone using with this?
Old Jan 3, 2006 | 02:12 AM
Matts72's Avatar
Matts72
The 6.9/7.3 IDI was a factory option, you can buy motor mounts or make them, the C6 is probably the easiest tranny to go with, no computer and no clutch to mess with, its also wicked strong.
