Oil & Lubrication
Switch from M1 to MC
Old Dec 27, 2005 | 01:52 PM
deano2's Avatar
deano2
I'm thinking of switching from M1 5w30 to MC 5w20 semi-syn.
2000 F150 5.4, 93,500 mi. Been using M1 since 1st oil change. Regular OCI = 5000 mi. w/ MC FL-820s oil filters.
Reason: cost.
6 qt M1 5w30 = +/- $30.00
6 qt MC 5w20 = +/- $9.00
Let's just say, things have changed for me financially and I'm trying to save wherever I can right now, but would rather scrape together the extra $$$ for M1 if I'm going to bring any engine problems upon myself by switching. Need the truck to keep going. Thanks
Old Dec 27, 2005 | 03:42 PM
ford390gashog's Avatar
ford390gashog
it will be fine, both meet the same specs. one costs 21.00 less. go for it.
Old Dec 27, 2005 | 03:53 PM
Flash's Avatar
Flash
deano2, if you want to save even more $$ and have a Dollar Tree in the area, look for the Phillips 66 Semi synthetic blend. At $1.00 qt and it has more Gp III synthetic in the blend than most and has a great add package as well, it's darn hard to beat. It would be my pick over the MC, and for me, if it weren't for availabilty problems, I would run it in mine all of the time. Great oil at a great price.
Old Dec 27, 2005 | 03:55 PM
ford390gashog
flash i thought they were identical oils? also dollar tree has not stocked oil since July. but walmart sells it for 1.50
Old Dec 27, 2005 | 04:16 PM
Flash's Avatar
Flash
They are not identical oils. The Phillips Gp III basestock is from Korea where the MC is a European basestock (Hydroclear). The Phillips will have more (25-30% prox) synthetic versus the MC (10-15%). Both are great oils. The last time I was in a Dollar tree, they still had it. But I also don't have just down the road either. Might be worth the trip if they do still have it.
Old Dec 28, 2005 | 07:35 AM
deano2's Avatar
deano2
Ok, thanks guys. I will switch away from M1. I do have a Dollar Tree in my neck of the woods. I'll stop in and see if they have the Phillips 66 stuff. If not, I'll check Wal Mart. I know I can get MC 5w20 semi at Wal mart, that's where I priced it and 6qts = $9.00. Thanks again, I learn more in this forum than anywhere else.
Old Dec 28, 2005 | 02:59 PM
ford390gashog
flash all of connoco's new semisynthetic oils are called hydroclear on their website.
Old Dec 28, 2005 | 11:19 PM
mikemic's Avatar
mikemic
Motorcraft should be fine for a 5K interval. I like synthetics for extended drains and very cold climates, but I don't believe they are necessary otherwise.
Old Dec 29, 2005 | 04:59 AM
DOHC's Avatar
DOHC
Conoco's Hydroclear is just a branded line of packaged oils . ConocoPhillips is the exclusive marketer of S Korea's S-Oil Corporation’s Ultra-S Group III base oils that are offered in 2 , 3 , 4 , 6 and 8 cSt's .
Conoco's trademarked Pure Performance groupII base oils are refined in Louisiana .
I would think when Conoco Phillips uses PAO's and Esters they get them from Chevron Phillips right here in the USA . No ,not a typo ..ChevronPhillips
