un less it has been moved from where the 04 is its on the frame under the drivers seat and u need a special tool to remove it if u break the clip it will cost u a bunch cant just buy the clips u have to buy the fuel line as well. im sure if u look this has came up before try using search
the fuel filter is under a black plastic cover which is part of the fuel tank. pop the cover and the fuel filter is there. the filter is hte new 3 prong version and is only available form ford for now. runs 30.00
gashog, Thank you very much for your help, I will take a look tonite at work.
73 mach1, I did use search......... nothing came up,Sorry to have bothered you!!
Man I need to get it submitted as a tech article......
you guys with the new f-150 have it easy! the new expy's are hidden in the side of the gas tank and the filter is a 3 prong which runs 56.50 from napa. I wish mine was only a 6.00 part.
