Bilstein Shock installation Tips
Old Dec 26, 2005 | 04:07 AM
SilverBullet131313's Avatar
SilverBullet131313
Hey guys....Have a 2001 F250 4 x 4 Just to refresh.
Got some Bilstein Shocks for Christmas for stock height.
First i want to confirm i have the right part numbers and shocks:
BE5-2828-HO Fronts i believe
BE5-2819-HO Rears i believe
I will probably be installing this week...so figured i would ask if any tips, advice, tricks...etc etc That any of you guys have done or easiest way to do them vs another way. Like Leave truck on ground when changing or truck on jackstands ?, Any specific torque specs on any or all the bolts/nuts? Should grease the bushings or anything? If so what is best type of grease to do that.
Or anything else to add..please do.
Thanks
Tony
Old Dec 26, 2005 | 07:00 AM
convincor's Avatar
convincor
"Never Seize" on the bolts. No need to jack it up.
Old Dec 26, 2005 | 07:01 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i would spray the bolts and nuts with penetrating oil now, that way the bolts aren't a pain to get off when you want them to get off the most.
Old Dec 26, 2005 | 03:38 PM
Steve_250's Avatar
Steve_250
SB, the Article link at the top has lots of goodies in it.
Here is exactly what ye seek, even with pics!
https://www.ford-trucks.com/article/...Absorbers.html
Old Dec 26, 2005 | 04:41 PM
SilverBullet131313
Steve250...yeah i already read that and saw pics before i posted this thread. But that is for an f150...so was just seeing if anything else possible was different.
Thanks
Old Dec 26, 2005 | 07:04 PM
UA250's Avatar
UA250
Not sure about the 2001 but on my '99 the front shock was 2818 not 2828.
Old Dec 26, 2005 | 07:33 PM
Steve_250's Avatar
Steve_250
Yep, 2818 & 2819 for non-lifted 4wd.
Old Dec 27, 2005 | 08:39 PM
SilverBullet131313
Yeah ...Sorry it was a typo..i have 2818s and 2819s
Old Dec 27, 2005 | 09:35 PM
1997F-350's Avatar
1997F-350
the fronts are easy...stand by for the backs. once they extend oh man trying to compress them and get it to go over the stud is a pita..trust me.
Old Dec 27, 2005 | 09:49 PM
Orezona's Avatar
Orezona
To do the backs I removed the spare tire and sat under the truck with my legs crossed, facing the shock mount. Mounted the to first so I could "curl" it up with both hands. I'm no Arnie, so it took some doing.
Old Dec 28, 2005 | 09:56 AM
Skeetshooter's Avatar
Skeetshooter
My 2000 Crew 4x4 has 59k on it, I think its past due for a set of shocks. Where is the best/cheap place to buy four Bilsteins???
Jeff in NM...OUT
Some call it a six pack, I call it a support group...
Old Dec 28, 2005 | 11:52 AM
Orezona's Avatar
Orezona
Jeff in NM...OUT
About a year ago, the best deal I could find was on eshocks.com. $64.95/each and free shipping. It came out to about $20/each cheaper than getting them anywhere locally (indianapolis).
Old Dec 28, 2005 | 04:07 PM
wilbur996's Avatar
wilbur996
I've used a ratchet type tie down to compress the shock to the correct length before trying to install it. Bilsteins are very hard to compress if you don't have the upper body strength while on your back under the truck. The tie down method works well for shocks with eyes on both ends.
Ditto on spraying everything with PB Blaster or similar a couple days ahead of time.
Old Dec 28, 2005 | 07:08 PM
Orezona's Avatar
Orezona
Now you tell me. The fronts let's say, made me angry.
Old Dec 28, 2005 | 08:43 PM
hink10's Avatar
hink10
I have an Excursion so not sure if is the same mount, but I used small hydraulic bottle jack to compress the rear shocks. Worked really well.
