Thachometer wireing
Old Dec 25, 2005 | 07:15 PM
Big Block Boy's Avatar
Big Block Boy
Cool Thachometer wireing
I just got a new Faze 5" monster tach with shift light . It's sweet, but the wireing however is not. I understand the ground, positive and coil wire, but the dimmer switch wires and shift light wires, I have no idea. I hate wireing.
I cant wait to get it hooked up though. I also don't understand the " For dash lighting dimmers that control the positive side of the dimmer circuit", and " For dash lighting dimmers that control the grounded side of the lighting circuit". I really hope somebody can help me out here.
Thanks guys
Dustin
Old Dec 25, 2005 | 08:41 PM
Ford_Six's Avatar
Ford_Six
These trucks control the positive side of the dimmer circuit, tap into the wire off the light switch rheostat for the tach light. Not sure on the shift light wiring.
Old Dec 25, 2005 | 08:58 PM
smecomark1's Avatar
smecomark1
I have tapped into the wire that provides power to the ash tray light, its easy to find/hook up and works great.
Old Dec 25, 2005 | 08:59 PM
go_racing84's Avatar
go_racing84
Do you have a test light? Ground the alligator clip end of the test light, turn on your parking lights, then poke around on your headlight switch connector until it lights up. Keep the test light there, then turn your dimmer switch up and down. If the test light gets dimmer and brighter when you do that, that's the wire you need to tap. And as Ford_Six said, it is a positive wire.
EDIT: smecomark1 has a good idea too.
