Wheel base
Old Nov 29, 2001 | 01:26 PM
beartracks's Avatar
beartracks
Wheel base
Any one ever notice their wheel base being different from side to side? My left front wheel is an inch father forward that the right. I noticed this after searching for the cause of a slight pull to the left after dropping the truck 3" all around. Everything is new in the front end and properly aligned. It also sits evenly all around (still a bit higher in the back).
It also seems to have a slight amount of bump steer (always to the left). It drives mucho better than before if I could just figure this pull out. If the wheel base should be equal I may move the radius arm support back on the left side.
Harold
Old Nov 29, 2001 | 04:00 PM
rc351w's Avatar
rc351w
Wheel base
Check the center bolt on your rear springs. If one has sheared off it will allow that side to shift (generally back) causing that side to have a longer wheel base and make the truck 'dog track', you see big straight trucks going all the time in this condition.
RCC
Old Nov 29, 2001 | 09:31 PM
beartracks's Avatar
beartracks
Wheel base
RC, Thanks for the thought. I did have a leaf removed from the back springs when I dropped everything. I looked at the "U" bolts and perches and it looks like a Yahoo tightened them down. Not evenly tightened at all. I'll loosen and retighten those guys. If the center bolt was broken wouldn't part of it fall out?
Bear
Old Dec 3, 2001 | 12:35 PM
beartracks's Avatar
beartracks
Wheel base
Anyone ever actually measure the wheel base on both sides?
Bear
Old Dec 4, 2001 | 03:57 PM
rc351w's Avatar
rc351w
Wheel base
Wheel base on both sides should be the same, otherwise the truck would hold the rosd like glue one way and hanndle like hell the other. If the u-bolts were loose, there's a good chance that the center bolt got sheared off. The only way to be sure is to drop the u-bolts and raise the body/frame so that the spring pack comes clear of the perch. The center bolt goes through the spring pack and the head sets down in a hole in the perch and keeps the axle in line. If the head of center bolt sheared off, it would remain in the hole in the perch.
RCC
Old Dec 4, 2001 | 05:56 PM
Cowboy_351's Avatar
Cowboy_351
Wheel base
sd75mac
2009 - 2014 F150
Jun 11, 2014 11:18 PM
harold1814
Projects
Dec 25, 2012 01:48 PM
harold morgan
New Member Introductions
Mar 20, 2007 09:53 PM
smiller4597
Nov 4, 2005 07:52 PM
hrsitton
Dec 1, 2002 08:46 AM
