Computer question
Old Dec 24, 2005 | 11:46 AM
Gottaford's Avatar
Gottaford
Computer question
I have an hewitt/packard computer that is about 5 years old. I want to put in another memory stick. I see that more than one stick can be put in there, but am I supposed to remove the old one, or do I need to keep it in there.
Thanks.
Michelle's Gottaford
Old Dec 24, 2005 | 11:49 AM
MisterCMK's Avatar
MisterCMK
You should leave the old stick in there.
Old Dec 24, 2005 | 11:51 AM
Gottaford's Avatar
Gottaford
Is it that it has old memory in it or does it help make the new one work better, or what?
Old Dec 24, 2005 | 11:53 AM
DainBramage's Avatar
DainBramage
It's just quantity.
The more, the better. Leave the old one in, plug the new one in, problem solved.
NoMo's Avatar
NoMo
Memory is cheap- especially the vintage you need. I'd recommend that you just buy two new "matched" sticks of memory to give you the desired upgrade.
If money is really tight, you can try to keep the old one and just buy a single new stick. Depending on how the system was manufactured, that may not be possible. But its worth a try.
Old Dec 24, 2005 | 11:55 AM
Gottaford's Avatar
Gottaford
A friend bought one for me for $80. Does this sound right?
Old Dec 24, 2005 | 11:56 AM
MisterCMK's Avatar
MisterCMK
yes it does
Old Dec 24, 2005 | 11:57 AM
Gottaford's Avatar
Gottaford
He was thinking about taking the old one out and that's why I asked. I'm really stupid when it comes to computers. Thanks for your help.
Old Dec 24, 2005 | 12:47 PM
slash31938's Avatar
slash31938
i have allways just put in as much as the bank will hold. some people say that they need matched pairs, but these are usually the people selling the stuff to ya. just cram in as much as you can, you will notice a big difference though.
Old Dec 24, 2005 | 12:50 PM
preppypyro's Avatar
preppypyro
Yes, the more the merrier, go as big as you can.
Old Dec 24, 2005 | 02:07 PM
OSin86's Avatar
OSin86
You only really need "matched" if you're running dual channel and 5yrs ago your system wasn't designed with dual channel. Keep them both in there, your system will be happier. $80 sounds good if it's 512mb other wise he payed too much. Good Luck
Old Dec 24, 2005 | 04:01 PM
NoMo's Avatar
NoMo
Well, I'd have to say "maybe". I've done a lot of PC support for a large company and have seen more than one occassion where mis-matched DIMMs caused stability problems. It may not be as big of a deal today- or in a home environment- but I still think it's best to match them. Of course, if they work together, then that's great!
Old Dec 24, 2005 | 04:05 PM
fordboy_52's Avatar
fordboy_52
i hope he matched the cas latency or your going to have troubles...
MAtt
Old Dec 24, 2005 | 05:49 PM
chrono4's Avatar
chrono4
with somting that old, the old stick could become the limiting factor in the bus speed, but like said, the more the better.
Old Dec 24, 2005 | 06:08 PM
OSin86's Avatar
OSin86
MAtt
Not always, I've had several old systems run on 2-3 mixed.
