Sponsored by: Auxito
won,t go
Old Dec 24, 2005 | 09:45 AM
sd150's Avatar
sd150
Question transmisson Help
I have a f 150 4x4 5.4 2002 last night the overdrive light came on. Now the truck will only move in reverse. When you put it in any forward gear it kills the engine and check engine light stays on. Tranmisson fluid is ok HELP. My son just got accepted in the USAF Wed. Would like to get this solved for him before he gets his orders.
Old Dec 24, 2005 | 01:11 PM
Beast12's Avatar
Beast12
Hi and welcome to FTE! Be sure to read this to help you around this site: https://www.ford-trucks.com/forums/s...d.php?t=300691 There are also State, Provincial and International Chapters located near the bottom of the main forum page.
We are glad to have you. Hope you enjoy the site. Check out the various forums. Lots of great info for you.
Thread moved to 97-2003 F-150 forum.
See ya on the boards!
-Matt
Old Dec 24, 2005 | 03:31 PM
steve(ill)'s Avatar
steve(ill)
i dont know if its an internal problem or computer related. I think i would pull the posistive cable off battery. crawl under the truck and check the electrical plugs on the side of the transmission. maybe pull them off and clean- reinstall. make sure all are connected. then reinstall the battery cable---- hope for the best. might also see if there area any codes given by the computer since the light is on, but you probably can not get to Auto Zone to check codes?.
Old Dec 25, 2005 | 12:53 AM
LxMan1's Avatar
LxMan1
Sounds like the torque converter lock-up solenoid is stuck so there is no slippage when in Drive.
Ranger Bob
2004 - 2008 F150
Dec 22, 2013 08:42 PM
ctspruill
1997 - 2003 F150
Apr 9, 2009 07:03 PM
bartamos
1997 - 2003 F150
17
Dec 13, 2006 03:16 PM
swampler
Modular V8 (4.6L, 5.4L)
Oct 18, 2004 11:50 AM
luckild
1997 - 2003 F150
15
Oct 3, 2004 11:17 AM
