General Automotive Discussion
Ahhhhhhhhh!!! Chevys!!
Old Dec 23, 2005 | 07:48 PM
76 F-150 390FE's Avatar
76 F-150 390FE
Cool Ahhhhhhhhh!!! Chevys!!
i have been working on my uncles chevy for about a week. he blew a head gasket i offerd to do it. BIG MISTAKE. this thing has faught me sence day one. we pulled the intake lifter valley was coverd in half an inch of sludge. pulled the valve covers.. same deal. 2 days of cleanin and all in sub freezing temps. the rest was spendin findin out where all the little brackets and that crap went. stopped on monday cause i needed rest wakein up at 7 for school and satyin up till 3 was takein it toll on me. last night i got bored and set the timeing as best i could with out a 2nd person. today go it fired up blew all the crap that was in it out, just went to fire it up 5mins ago look at the guages and NO OIL PRESSURE none at all. the dizzy is seated and there is oil in it. i am on my last nerve with this truck. please any help with this.
Old Dec 23, 2005 | 10:29 PM
jimbo beam's Avatar
jimbo beam
take it out behind the barn and put it down old yeller style
Old Dec 23, 2005 | 10:34 PM
76 F-150 390FE
i keep sayin im gonna shoot it, and it somethin dont happen soon, well i just might havta. does anyone know if buck shot will go through cast iron? or will i needa get the ol 30-06 out with the armor piercing?
Old Dec 23, 2005 | 10:47 PM
Fomoko1's Avatar
Fomoko1
Save yourself all that trouble and just place an ad. Might end up with afew $$. Not as much fun as shooting it but the neighbours will be lot happier.
Old Dec 23, 2005 | 10:54 PM
76 F-150 390FE
no i havta get it done its my uncles truck and he needs it. if it was my truck then i wouldent care what the neightbors thought at bout this point. it runs, it runs fine just no oil pressure im gonna go pull the valve covers to see if the guage died or the sensor fried but it was workin when we started.
if i didnt have my carb off my truck i would have pulled it around the mountain like a toy alredy.
Old Dec 23, 2005 | 11:03 PM
Fomoko1's Avatar
Fomoko1
If you have to get it going that`s a different story, maybe some of the sludge is causing the problem. I don`t know how hard it is to pull the oil pan but you may have to do it. Good luck, just remember to stay away from chebbies.
Old Dec 23, 2005 | 11:04 PM
pfogle's Avatar
pfogle
In a chevy motor there is a nylon ring that the oil pump drive shaft seats into. Pull the oil pan and make sure it's not broke.
Old Dec 23, 2005 | 11:10 PM
77F-150's Avatar
77F-150
If he blew a head gasket and if it was me, i wouldnt mind doing it. You learn something new with every make you work on, the experience counts.
Old Dec 24, 2005 | 12:27 AM
76 F-150 390FE
i no i didnt really mind doin it, its just the fact that its fightin me like this, im gonna havta pull the pan anyways, we never got to clean it out, when we were done the heads and lifter valley were almost spotless. it had pressure when he drove it in, the only thing i can think of is somethin got lodged some where, or the ring that pfogle is talking about.
Old Dec 24, 2005 | 12:28 AM
76 F-150 390FE
o i also pulled the valve covers and the lifters were just as dry as when i put them in the guage dont lie
Old Dec 24, 2005 | 02:27 AM
A_G's Avatar
A_G
i feel your pain. My friend has a 87 chevy with a 305 in it
When he got it, it was running, like crap...like a chevy. So we pull the heads, carb, manifold, and all electrical and vacum lines.
First off hes got a 350 style carb hooked up to a 305 modified manifold. So its not getting good mixture
I put in 40 hours helping him fix it...what a POS...i almost shot it..while he was sleeping..
Old Dec 24, 2005 | 12:45 PM
davethecow's Avatar
davethecow
Ive never had too many problems working on the small block chevys that i own.You never said what motor your uncle has.most gm motors are preety basic,i did say "most".
By far the biggest pain is setting points on those stupid rear dizy's.
Old Dec 24, 2005 | 03:25 PM
76 F-150 390FE
it is an 89 350 EFI
Old Dec 24, 2005 | 07:52 PM
go_racing84's Avatar
go_racing84
Um... you didn't knock the wire off the pressure sender or kink the tube (depending on what it uses), did you?
Another thing... and I have to ask this... did you drain all of the sludge out and put fresh oil/filter in?
Old Dec 24, 2005 | 08:51 PM
F2504x4's Avatar
F2504x4
after you check these, get a real oil pressue gauge and check it first before dropping the pan, this way you will have a true reading and not from an idiot gauge. do i need to explain why they are called idoit gauges?
