e4od and c6
Old Dec 23, 2005 | 06:36 PM
Diamond Jim's Avatar
Diamond Jim
e4od and c6
would the output shafts be the same in these trannys and if so how big of a job is it to change them. i want to turn my e4od 2x4 into a 4x4. What would the cost of an output shaft be worth.
Old Dec 24, 2005 | 07:00 AM
rclarke's Avatar
rclarke
C6 and E4OD output shafts are different. Some other internal parts are the same. The output shaft is the last thing to come out of the transmission case. You will also need a new extension housing. Changing to 4x4 configuration would be the same as overhauling the transmission.
fudimanuchi
Apr 1, 2012 07:06 PM
92 f150300six
Aug 8, 2003 04:32 PM
