more milage?
Old Dec 23, 2005 | 01:20 PM
jiminpa2's Avatar
jiminpa2
more milage?
what can be done to improve the milage on the 5.4l? i've went to synthedic oil (diffs,engine and tranny) and a k&n filter.would headers help?chips?exhaust? i get 11 mpg now(81900 miles).
Old Dec 23, 2005 | 01:24 PM
ford390gashog's Avatar
ford390gashog
11 mpg is a little low. when was the fuel filter changed? plugs? you should be getting 12 to 13 mpg
Old Dec 23, 2005 | 01:42 PM
jiminpa2's Avatar
jiminpa2
yes fuel filter was changed.also plugs at 75000 miles.i do all my own maintence by the book.
Old Dec 23, 2005 | 07:30 PM
kspilkinton's Avatar
kspilkinton
Do you have any other mods... perhaps larger/heavier tires? Anything sticking up off the truck? Big canopy? Brush guard? Options add weight which will affect your mileage. Are we talking about towing something? I get 10mpg with a 6000lb trailer. Like to drag race at stop lights? seriously... I know some people have poor mileage because they need to to see what the 0-60 time is at every light... That'll make your mileage tank pretty quick.
Old Dec 23, 2005 | 10:02 PM
LxMan1's Avatar
LxMan1
What exactly are you working on? 4x2, 4x4, SuperCab, SuperCrew? Gear ratio, tire size?
Driving downhill always helps mine
My 01 SuperCab OFFROAD 4x4 3.55 gears and 265/70-17 tires gets about 13mpg on average.
If you let it idle alot to warm up etc, that will kill the mileage too.
Old Dec 24, 2005 | 07:44 PM
jiminpa2's Avatar
jiminpa2
brushgaurd on front,topper,stock size tires.i've got 10-11mpg since it was new.i blew a plug(the infamouse #3) and since i'm stuck with it i was thinking of replaceing the heads(not with ford ones)and mabe bombing it up some.headers and exhaust,fuel chip.suggestions?
Old Dec 24, 2005 | 10:18 PM
mat-helm's Avatar
mat-helm
High flow cats would help, or better yet gut the cats if you can get away with it up there. And put some mil eliminators on the rear O2's.
Old Jan 2, 2006 | 01:46 AM
Fishsimion's Avatar
Fishsimion
Let me know if you find any good way to boost it. I pretty much have just figure its the cost of having a superduty.
I have a 99 F250 SD SCab 4x2 and I usually get about 8 to 10mpg in town and 12-15 on the highway with out towing/hauling anything.
When towing my brothers travel trailer I usually get about 4 to 6mpg in town and 6 to 8 mpg on the highway, unless going downhill then the truck shows 14 to 16mpg until I level out.
Old Jan 2, 2006 | 02:09 PM
kspilkinton
I had completely forgot about the fact it could be a SuperDuty, or an Excursion for that matter. I see Jim's truck back at the start of the thread is an '02 F250.
The weight of that truck; It's larger, less aerodynamic front-end... what gears are you running... 3.73s, 4.10s, 4.30s... they'll be a factor.
These will definitely drag the truck's gas mileage down. You are going to be hard pressed to find a great improvement with these, or any trucks. Just remember, the more weight... figure on getting lower mileage.
-Kerry
Old Jul 16, 2006 | 07:59 AM
budfans's Avatar
budfans
you might want to look at what the V10 guys say there getting in there s/d
Old Jul 16, 2006 | 01:59 PM
CounterMaker's Avatar
CounterMaker
DRIVE SLOWER!!!! START OFF SLOWER!!!!!! i went from 11.4 mpg to 13.2 mpg just by driving slower...u use the most gas when starting off really fast...it takes alot to get that big boat moving....try and keep the rpm under 2000 and you will see a dramatic change...and best of all it doesnt cost you 300 bucks to drive slower like it does to go out and but a cat back exhaust or a superchip....
Old Jul 17, 2006 | 11:11 PM
Bayou_Flyer's Avatar
Bayou_Flyer
Agreed!
I have a 2005 Ex w/ 5.4 & though it's hard to do it, being gentle with the "go" pedal will help. In my case, it really didn't make any sense to be agressive around town, so I started taking my time in stop-n-go traffic. On the interstate, I try to keep it btw 70-75. Drives my wife crazy!!!!
I also added a CAI by Outlaw which picked up the fuel averagea little (based on two runs on the same stretch of I-12; cruise set @ 70mph). Round trip total of 40 miles per run ,and I reset the meter once up to cruising speed at the beginning of each 40-mile run. The meter averaged 15.5-16.0 w/stock intake, and then 17-17.5 after the CAI. Both measurements taken around mid day with ambient air temps around 92F. Almost flat terrain w/ only a few feet of elevation change at best (it is South Louisiana!!). I still only get about 12 in town, but it does weigh 3 tons!
Old Jul 18, 2006 | 10:04 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
O2 sensors "slide" rich, meaning the computer sees more O2 from them over time and compensates rich.
Other than that, slow down
Old Jul 25, 2006 | 10:29 AM
velcro7279's Avatar
velcro7279
I have a 2003 F 150 SC FX4 w/ the 5.4. Bone stock 3.55LS 40000 miles. We went to Pennsylvania on vacation in June and got 18.8 on the turnpike running about 72 mph. Thought that was pretty good for a fullsize 4x4 truck. That is the best we have gotten with it. It averages about 14-15 with mixed driving.
Old Jul 25, 2006 | 04:00 PM
biz4two's Avatar
biz4two
Arrow
IMHO...all the money spent on upgrades would be better to just buy the gas. The brushguard and topper do not help...as they add weight to an already heavy truck with a smallish engine.
It has been suggested by other FTE members, that adding a K&N or any other aftermarket filter actually causes the engine to use more gas. The reasoning behind it...is that the MAF and PCM see the increased air flow...and have to compensate with more fuel to keep that 14:1 or 12:1 mix going.
If possible, remove the K&N and go back to the stock setup. Clean your MAF sensor and disconnect the battery for one hour with the head lights on. This will erase your current PCM settings...and allow your truck to learn the new settings without the aftermarket filter. Keep your foot out of the pedal...and below posted speed limits by 5mph. You should see an increase by 2 or 3mpg.
Hope this helps some...and good luck.
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
