not charging
Old Dec 23, 2005 | 11:14 AM
dude73's Avatar
dude73
not charging
i have a 88 f250 7.3idi with a 5 speed i cant get it to charg ive had the alt bench tested and its fine changed the volt reg now it work every now and then it has a meter and a dummy light when the light is on volts at the battery 12.02 when its off 14.8 to 15.3
Old Dec 23, 2005 | 07:17 PM
thenutisloose1's Avatar
thenutisloose1
Make sure the voltage reg is well grounded & the battery cables are not
corroded inside
Old Dec 23, 2005 | 08:30 PM
sa_rains's Avatar
sa_rains
My brother had a 90' 7.3 with a similar and intermittent problem. On his truck, it was the wire connectors that connect to the alternator. After new batteries, new alternator, and new regulator didn't fix the problem, he replaced the connectors and hasn't had a problem since.
Old Dec 23, 2005 | 09:09 PM
PLC7.3's Avatar
PLC7.3
Check the small single wire from the alt it has a fusible link also the connector is known to burn up.
Old Dec 24, 2005 | 12:25 AM
dude73's Avatar
dude73
thanks to all i'll let u know what helped
Old Dec 24, 2005 | 11:36 AM
Heavy460's Avatar
Heavy460
My E250 was doing the same thing.It was the new alternator i bought from the auto store.After installing it out of the box it charged the battery for about 2 min then stop.It would do this every cold start.I took it back to the auto store three times to have them test it.Every time i took it back they said it was a good alternator.In the long run it was the alternator after paying some one to tell me that.
Dakota Byrd
Oct 19, 2014 09:58 PM
valley1221
Apr 25, 2013 09:21 PM
F-406
Nov 20, 2011 09:02 PM
ffm455
Sep 27, 2009 07:12 PM
drbigknuckles
Mar 5, 2009 02:13 AM
