Sponsored by: Innova
what subs to use
Old Dec 22, 2005 | 09:46 PM
1986_F150's Avatar
1986_F150
what subs to use
i got a 1986 f150 with a pioneer head unit, 2 3 way pioneers in the door and a 500 watt sony amp and was wondering what would be the best sub to use
Old Dec 23, 2005 | 05:58 PM
fordboy_52's Avatar
fordboy_52
2 audiobahn 10's
Matt
Old Dec 24, 2005 | 04:26 PM
hearing8's Avatar
hearing8
Where are you going to put the subs? You say you have a 500 watt amp....how many channels is it? What is the RMS power output of your amp at 4ohms? What type of music do you listen to?
If you can answer these questions it will help you choose the right amp for the equipment you already have.
Old Dec 24, 2005 | 08:22 PM
1986_F150's Avatar
1986_F150
its a 4 channel amp im puttin them behind the seat and i listen to really anything i can find
Old Dec 24, 2005 | 08:34 PM
RomerB2's Avatar
RomerB2
A couple 10's by Audiobahn will probably make you a happy camper. Simple and effective.
Old Dec 24, 2005 | 08:46 PM
hearing8's Avatar
hearing8
OK...so two channels to your mids and highs....and two channels for your sub(s)....if you couls give me a model number on the amp or specs on it I could be very helpful. If the amp has crossovers that would help alot also.
As far as saying just saying a couple of 10's...without knowing the parameters of the amp telling you that could be the worse thing to do...it also could be right.
For example:
if the amp is rated at 500 watts at 2 ohms that gives you 125 watts per channel. so if the back two channels are running a sub you need a woofer that will show a 2 ohm load to the amp....so a single 10" sub with dual 4 ohm voice coils will give you that load....or (2) 10's rated at 4 ohms...it all depends on the specs on the amp...and different amps show different power....A McIntosh amp sounds different than a Sony or Zapco....get me some specs and then I can help more....
Always remember that RMS and Peak power is different
Old Dec 24, 2005 | 09:33 PM
fordboy_52's Avatar
fordboy_52
yea, amps and subs are measured diff. rms is less than peak.
MAtt
