Help 1980 6 cyl
Dec 26, 2005 | 04:11 PM
Quote:
Originally Posted by built 80 f250
base engine was the i6 300 but ford offered the 3.8l v6 the 5.0l v8 the 5.8l windsor and the 460
Interesting. My shop 1981 shop repair manual doesn't mention a 3.8L v/6.
Maybe it was offered in 1980.
Dec 26, 2005 | 04:44 PM
It has to be a 300. Ford didn't offer any other engine in a inline six in the 80's.
Unless sombody put it in later...
I suspect somebody put the distributor in 180 degrees off.... My guess.
Dec 26, 2005 | 04:54 PM
81-F-150-Explorer, ditto on what you said.
Doesn't the 240-6 look the same as the 300-6?
Unless someone popped in a different engine, he "should" have a 300-6.
I think ramtoo should first try and re-install the distributor and fire it up.
If it's a no-go, then pop off the timing case cover and see what's going on inside.
Maybe the pistons are installed upside down. (kidding
Dec 26, 2005 | 05:15 PM
Same identical block and look yes it does.
Even right down to the valve rod cover on the driver side, and distributor, placement.
The head was different. Don't know how much, or any other differences, but just looking at them at a glance, it would be hard to tell them apart.
Dec 26, 2005 | 11:04 PM
I know its not just looking at the motor, but wasn't the biggest diff in the 240 and 300 just the heads and the stroke? Correct me if i'm wrong
Dec 27, 2005 | 10:21 PM
ok all of my trucks from 1980 to 83 all have decals on the rad support on the left side that declare the engine as well as a couple other things
Dec 27, 2005 | 10:31 PM
Quote:
Quite Correct, Olde Son, as the 300c.i.er is a Bored & Stroked 240c.i.er w/ a Larger Combustian Chamber Head!
franke67
Oct 7, 2012 11:43 AM
paintrx
Sep 19, 2012 10:59 PM
ramtoo
Dec 25, 2005 04:25 AM
F3Beam
15
May 12, 2005 07:24 AM
sodbuster54
Sep 13, 2002 07:19 AM
