steering adjustment
Old Dec 12, 2001 | 09:41 AM
78f250's Avatar
78f250
steering adjustment
Old Dec 13, 2001 | 03:21 PM
dbarracuda's Avatar
dbarracuda
steering adjustment
I have a 77 F-150 400m with power steering. The steering is loose and my Dad was telling me that you can adjust it a little with the adjustment screw on the steering box and that might help some. Is there any thing I need to know befor I try this? Thanks in advance.
David
Old Dec 13, 2001 | 04:23 PM
dfisher1's Avatar
dfisher1
steering adjustment
David,
This is an easy thing to do. Don't worry about all the stories you hear about how sensitive this "procedure" is.
Simply loosen the locking nut on top of the steering gear several turns. Insure the center bolt stays still while you loosen it. Simply take a screw driver and tighten the bolt clockwise until it is snug. Retighten the locknut.
Now, your an expert.
The following symptoms may result:
1. The steering does not return to center after a turn, your too tight. Solution, drive it till it wears in or simply loosen bolt a little.
2.You still have too much play in wheel. Solution: tighten bolt some more but, this time crank down on it! Your steering gear is trashed and it's probably too late anyways.
3. Can't get the play out. Solution: Buy a new steering gear for $160 or find the play someplace else.
a. Tierods.
b. Pitman Arm
c. Draglink
Good luck, Have Fun,
KingFisher
Old Dec 13, 2001 | 06:19 PM
dbarracuda's Avatar
dbarracuda
steering adjustment
Thanks. I will try that. Hopefully it will fix the problem.
David
