steering column
Old Dec 14, 2001 | 04:10 PM
oft's Avatar
oft
steering column
Hi there,
I am taking my steering column apart. The collar that the blinker assembly is attached to, anyone know how to get it off? I took out the blinker assembly, removed the two bolts holding the collar in and it wont come off. I moved it about 1/4 incnch but that's it. Any suggestions?
Jayson
Old Dec 14, 2001 | 04:50 PM
dfisher1's Avatar
dfisher1
steering column
Jayson,
There is a C-clip that is holding it in there. Push down on the blinker assembly to expose it. Use an ice pic and snap ring pliers, if that's the type of C-clip you have, to get it out of the groove. After you get the clip out, disconnect the blinker gang plug and slide the blinker assembly off of the column shaft. you've made it to the shifter assembly. It will come out easier than it will go back in.
Good Luck, Have Fun,
KingFisher
Old Dec 14, 2001 | 05:17 PM
DantheMan's Avatar
DantheMan
steering column
