You have to watch the plastic casing on batteries, especially rechargeable ones because they get reused and wear more. I was messing around with some batteries that I pulled out of a power-pack of some sort, peeled off the plastic that was holding them together and there was no individial casing on the batteries, just the metal shell. Anyway, I put some of these batteries in a camera flash that took 4 batteries, after shutting the compartment, about 30 seconds later I could smell plastic burning. I noticed it in time to save the flash, there was only some warpage on the compartment cover. If I had left as soon as I put those batteries in, there probably could have been a fire, as all the batteries were just out of the charger.
I should also mention that I have taken it upon myself to take a piece of scotch tape and tape around the circumference of batteries at each end to protect or repair the casing. Have to be careful where I use those though, so they don't get stuck in something.
Also, if you buy one of the charger/battery combo packages, make sure you have a close look at the batteries in the package because they use those combo packages to get rid of the lower mA/hr rated batteries.
